Double roller timing chain?
Old Dec 6, 2013 | 09:01 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
I know they make a double roller timing chain for the 3.1L...... but what exactly would have to be modified to fit it and would there be any real benefits of it?
Old Dec 6, 2013 | 09:07 AM
project89's Avatar
Re: Double roller timing chain?
nothing its made for it it bolts on
Old Dec 6, 2013 | 09:46 AM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Yup. I had one in my old 2.8.
Old Dec 6, 2013 | 10:37 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
i knew it would fit but it says something about having to modify the damper? I'm not even entirely sure what that part is
Old Dec 7, 2013 | 12:48 PM
willexoIX's Avatar
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
I do not believe that you have to modify anything, when I bought my 89 2.8, it already had one of these. Don't know how old it was but it was stretched like hellll. Went back to single tooth and no problem since, about 80,000 miles on it.
Being that I dont know how it is when its new, does it even make a difference?
Old Dec 10, 2013 | 09:46 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
would I have to change out the gears though because would I need a double gear or something like that for it?
Old Dec 10, 2013 | 09:49 AM
project89's Avatar
they come with the new gears, unles su buy just the replacement chain
Old Dec 10, 2013 | 10:03 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
ok well would this be a good one to buy then? http://www.engine-parts.com/GMV6/gmv6tmg.html
Old Dec 10, 2013 | 10:11 AM
project89's Avatar
in all honesty just goto napa or ur local parts place and get a stock replacement last time i got a set i think it was 32 bucks
u wont notice any gains from a double roller , hell i use the stock chains on my turbo builds
Old Dec 10, 2013 | 10:20 AM
BiggTipp7's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6 Auto
Axle/Gears: 3.27?
ok then thats what I will do thank you project89
Old Dec 10, 2013 | 03:41 PM
Barlow8869's Avatar
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
also, from what i have read in the past, if you get a double, as the chain starts to stretch, it will make the timing go off farther than a single, do to the mass of the chain, and the friction of the chain on the sprockets
Vintageracer
Jan 10, 2020 05:33 PM
junkcltr
Aug 2, 2019 11:12 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MY87LT
Aug 17, 2015 08:43 AM
BrianI
Aug 9, 2015 11:52 AM
