distributor replacment?
Old Jan 5, 2015 | 07:35 PM
Dutch420's Avatar
Car: 89 RSt-top
Engine: 2.8 mpfi
Transmission: auto
hey everyone got a question
got my car running pretty good still a small miss at idle and have to set tps proper (volt meter wont go that low). but im assuming the miss prob is related to my distributor problem.
now my question is, when the rpms drop from a shot of gas i can hear and feel a vibration/grinding noise form my distributor. im assuming it on its way out, has some side to side play and the pickup coil can move around on the shaft. i assume the noise and vibration is a mix from the side to side play and pick up coil moving around on the shaft.
im looking at buying another from rockauto. there is 2 im looking at need some opinions
- WORLD POWER SYSTEMS Part # DST1633 ... comes with everything not sure on quality.
- CARDONE SELECT Part # 841633 ... this also comes with evrything not sure about this either.
im assuming the cardone part is better but could use some help here.
thanks everyone
Old Jan 6, 2015 | 09:25 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: distributor replacment?
Get the AC Delco Distributor for $120.
ACDELCO Part # 88864747
If there is anything to remember when dealing with sensors, relays, ignition components, try to use GM parts where you can. You'll pay a little more, but worth it in the long run.
JMO
Old Jul 23, 2015 | 12:56 PM
Ce84q8's Avatar
Car: 1984 Camaro
Engine: V6 2.8
i would use ac delco / origional gm parts, they last the longest. did you check your ICM? could be a the begninig stages of failure
jklein337
Sep 19, 2018 06:23 PM
Derick15
Sep 17, 2016 05:28 PM
86IROC112
Aug 17, 2015 07:57 PM
92camaroJoe
Aug 13, 2015 06:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
