new engine probem!
Old Jul 18, 2015 | 04:36 PM
92projectcamaro's Avatar
Car: 1989 rs coupe
Engine: 2.8 turbo build
Axle/Gears: 3.27 posi
new engine probem!
things can never go as planned right lol so I did my 3.4 swap got all back together when I was done found out I had electric issue starter was bad replaced that now my engine will crank but it wont start just cranks and back fires out of exhaust and throttle body. im thinking its a timing problem? if im right how can I fix the problem?
thanks In advance
Old Jul 18, 2015 | 06:06 PM
Car: 1989 rs coupe
Re: new engine probem!
could it be bad timing chain
Old Jul 19, 2015 | 03:41 PM
Car: 1989 rs coupe
Anyone?? I need some help
Old Jul 19, 2015 | 04:30 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Check timing. We had that happen to us with an sbc- it wouldn't start for anyone. Then we rotated the dizzy 180 and boom - fired right up
Old Jul 19, 2015 | 04:32 PM
Car: 1989 rs coupe
The timing chain?
Old Jul 19, 2015 | 04:33 PM
Car: 1989 rs coupe
I just so confused every thing I look up to adjust timing the car is on my car wont start lol
Old Jul 21, 2015 | 12:26 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
As Alex said, check the distributor to make sure you don't have it 180 degrees off. That's easier to check than pulling the timing cover off. Also, make sure all your plug wires go from the correct spot on the cap to the right cylinder. Since it's popping out the intake, it does sound like you're 180 off, likely on the dizzy.
Old Jul 21, 2015 | 12:27 PM
Car: 1989 rs coupe
How do I fix the dizzy?
Old Jul 21, 2015 | 12:31 PM
drdave88's Avatar
Engine: 6.0L
Not to sound like a jerk, but do you know how to set timing? You can't just drop the distributor in the engine. It has to point at a certain spot with the #1 cylinder on TDC compression stroke. If you are unfamiliar with it, do a search or check out some YouTube vids on setting distributor timing.
Old Jul 21, 2015 | 12:58 PM
Car: 1989 rs coupe
Yes ik how to but wat confuses me is it was never removed or changed this just happen out of no where the car was running a week ago
Old Jul 21, 2015 | 01:05 PM
drdave88's Avatar
Engine: 6.0L
OK in your first post, you never stated the engine was running. All you said is you put the 3.4 together and then found out you had issues. We understood it as you were trying to start it for the first time and had this issue.
How was the car running before?
Was there any misfire, hesitation, bucking/jerking, stalling?
Did you put a new chain on before you put it all back together, or is this the original chain?
Old Jul 21, 2015 | 01:07 PM
Car: 1989 rs coupe
Original chain and it actually ran surprisingly well no jerking. Or backfire was actually pretty smooth
Old Jul 21, 2015 | 05:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
THe dizzy hold down can feel tight but sitll allow movement, had to really horse mine down to stop small ammount of movement that made it run great, then like crap.
Old Jul 21, 2015 | 05:28 PM
drdave88's Avatar
Engine: 6.0L
Pull the cap, recheck your timing to make sure it hasn't moved too far off from Cyl 1 on TDC comp.
Old Jul 21, 2015 | 05:36 PM
Car: 1989 rs coupe
Could the rotor cap it's self be bad
Old Jul 21, 2015 | 05:40 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Take the plug out of the #1 cylinder. Put your thumb over the hole. Turn the engine over slowly with a breaker bar and socket on the harmonic balancer bolt. When you feel pressure pushing your finger away from the hole you are on the compression stroke.
Then look at the timing mark on the harmonic balancer. It should be close to top dead center (pointer pointing at the mark). Turn it the rest of the way to Top Dead Center.
Then find the number one plug on the distributor cap. Should be the wire to the plug you took out. Unsnap the distributor cap and see if the rotor is pointing towards #1. If it is pointing the opposite direction you are 180 out.
You can find all this in the Haynes manual for your car available at auto parts and book stores.
Old Jul 22, 2015 | 12:09 PM
drdave88's Avatar
Engine: 6.0L
If that was bad, you wouldn't have spark. The cap and rotor are what deliver spark to the plugs. You are getting spark, but it sounds like at the wrong time.
Old Jul 22, 2015 | 03:00 PM
Car: 1989 rs coupe
Do I took the number one plug out and the #1 cylinder is at tdc. But when I pop the cap off the rotor wasn't at the number one wire
Old Jul 22, 2015 | 06:25 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
4 stroke engine, piston comes to the top twice, make sure its the compression stroke.......
Old Jul 23, 2015 | 03:30 PM
Car: 1989 rs coupe
Okay I'm still at a loss I made sure the number one piston is at tdc. And the .the rotor is fixed back so it's on the number one plug and the same thing is happening just cranking and backfiring I really wanna figure out wats wrong so I can fix it
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
