where does this go lol
Old May 22, 2015 | 03:09 PM
Kishan's Avatar
Car: 1989 Trans Am
Engine: MPFI 2.8L & 3.4(3500 hybrid)
Transmission: Manual
so i've finally got around to working back on my 89 trans am, but its been quite some time since i ripped apart the dash wiring and headlight harness.
before i go any further i should mention that I'm using an 86 firebird 2.8 harness which including chassis,body, and eng harness. EVERYTHING from the 86 was transferred over to this 89 trans am shell.
i have all the wires connected under the dash except this one with a purple and pink with black tracer on it. its closer to the steering coloum side of the dash near the drivers foot panel area...
can someone help me out here
also i need to know how the headlight harness is routed. if someone can take some pics or give me a brief explanation that will be great!
Old May 23, 2015 | 05:14 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: where does this go lol
in 2 ways your lucky, #1 I know that connector and its doing what it does in my car, hang lose.
Cause #2 my feet are to big and I can't run the under dash plastic pieces so like every few months that dumb thing drops down and I have to tuck it back away.
Old May 24, 2015 | 09:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
TCC lockup power, goes on the brake pedal switch. Since you have a stick trans, it's as Gumby says, it hangs loose.
Note that the PNK/BLK wire is hot during key-on. So don't let it short against anything.
RBob.
Old May 25, 2015 | 01:52 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Amen,ive seen that hanging around in my five speeder to, I had an auto before so iguessed it was that. Tuck it away real nice .
Old May 25, 2015 | 12:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
RBob.
Is it fused?
Can it be used for say a stereo, or fog lights or?
Old May 25, 2015 | 01:35 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
On an '87 it is fused via the gauges fuse. I don't know the fuse size, so can't say whether it can be used for other items unless the power draw is within the range of the fuse and wire AWG.
RBob.
Old May 27, 2015 | 03:30 PM
Kishan's Avatar
Car: 1989 Trans Am
thank u guys. it was driving me nuts for awhile now and no matter which diagram i looked through its like i couldn't find the darn thing lol.
also any luck on helping me out about the headlight harness routing?
thanks in advance.
Old Jun 9, 2015 | 08:25 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
RBob.
it will run the fuel pump, ign modual died on way home but thought it was fuel pump, as that the onlything that has ever stopped the car from running, so I hot wired the fuel pump with it. [ ill undo it tomorrow ] alredy past bed time.
HoosierinWA
Oct 7, 2015 10:15 AM
Numbah-1
Oct 2, 2015 08:27 AM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
3.8TransAM
Sep 27, 2015 08:37 PM
