2.8 - 3.4 swap
Old Dec 22, 2001 | 11:07 PM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
2.8 - 3.4 swap (KED85 please help)
who on here has swapped a 2.8l for a 3.4l? what is envloved and what exactly will i need for the swap besides the engine. my grandfather is goin to get a rebuilt long block for the car (it ended up being cheaper than to rebuild the engine i had). what intake setup should i use since the 83 has a carb? im getting mostly new accessories (new ac, alt, smog pump) and new distributer and coil. im basically goin to follow what KED85 did.
https://www.thirdgen.org/techbb2/sho...light=3.4+swap
my only concern with this is the carb and fi?
Loomdog
Old Dec 22, 2001 | 11:44 PM
c-5invalid's Avatar
couldnt you get a used 350 for the price area of a new 3.4? after driving that chevelle i got to get a v8
Old Dec 23, 2001 | 01:02 AM
loomdog32's Avatar
Car: 82 Camaro Z28
i could get a 350 alot cheaper since i have one sitting in my garage. the only reason im not doin a v8 swap is the cost invloved. i would have to replace everything! engine, accessories, smog equipment (from donor car), exhaust, radiator, tranny, rear end ( 3.08 ). it would be cheaper to buy a new car than to do that. thats what i origionally planned on doing. then i was goin to buy a used 2.8, but got screwed over on that, then i was goin to rebuild the 2.8 in the car. while checking on prices for machine work and parts, i got prices on long blocks (2.8 & 3.4). they were the same. since i have to replace most of the accessories (ac, smog & alt) everything else SHOULD bolt up, since there the same block (2.8 stroked = 3.1. 3.1 bored = 3.4) the only questions i really have on the swap is
1. can i use the intake manifold & 2bbl carb w/ 3.4 heads
2. timing
and the heads from a fi 2.8 DO NOT work with a carb. thats y i had to take back the used engine i got. the injectors injected into the heads. i need to know if this is true with the 3.4 heads.
Old Dec 23, 2001 | 10:33 AM
KED85's Avatar
SAY WHAT
First do a search on the 2.8 3.4 swap boogie.
https://www.thirdgen.org/messgboard/...ML/001462.html
READ THIS ALOT. Read it several times, then look at your current engine bay. That's what ya end up with. Fast RS saw my set up and couldn't believe it. He was a little dissapointed. I'm not. I press the gas pedal
I am splitting for back east until Jan 9th.
I'll be able to answer any questions after then.
As an FYI, I have 1985 MPFI (came from the blown 2.8 in my 1985 Firebird) heads on my 1985 S-10 Blazer with a carb. They were perfectly fine. Fit & operate perfect.
Leaks? Your instance makes no sense to me at all.
Not a put down, but, this is what I've done and it works great.
PS I'm an IDIOT when it comes to working on cars. That's why I like it simple.
I had a BMW2002. What a piece of **** garbage can.
Our F body cars are very basic.
Sorry about NOT BEING ABLE TO VIEW OLD POST
Do hope that's fixed real soon!
Old Dec 24, 2001 | 01:51 AM
loomdog32's Avatar
Car: 82 Camaro Z28
the engine i got was susposte to be from a 85 camaro w/ mpfi. i didnt get the fi with the engine cuz they broke the hell outta it when they took it out of the car. ive found as few other things that have led me to believe that the engine was not a 85 camaro 2.8l mpfi. there r a couple ppl in fresno that r goin to get really chewed now for this. well its good to know the heads will work with the manifold and carb from the 83 (sigh of relief). ill be spending the next few days now reading and re-reading the swap boogie and checking on exactly what i need for the swap. apparently its goin to be no more work than replacing the 2.8 with another 2.8. cept now ill have something a lil bigger with more torque . i should have the engine pulled and have the 3.4 ready to drop in by the time u (KED85) get back. hopefully itll be an easier swap for me than it was for u (since i got directions from when u did it). well time to read.
loomdog
Old Jan 11, 2002 | 11:49 AM
KED85's Avatar
Hi Just got back to computer so I'm catching up on this thread.
Hope the swap is going ok.
Let me know if I can help ya more.
Should be fine, the weather up there isn't much different than here.
Bet it's windy there.
Old Jan 11, 2002 | 01:51 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
or if you still want to put in another 2.8L engine, this website has them bran new for $1,589 http://www.sdpc2000.com/cart.asp?act...tid=124&pid=84 im most likely going to get that when my engine goes, then im going to mod it up
Old Jan 15, 2002 | 01:54 AM
loomdog32's Avatar
Car: 82 Camaro Z28
im not exactly sure whats goin on with my engine build rite now.. i still have the used 2.8, that im tring to sell. my grandpa wants to only use/buy a rebuilt engine. hes only wanting to buy a 2.8 and im not goin for that. any ideas?
it hasnt been that wendy here lately. u should take a drive up.. it would be a BIG help for the 3.4 swap to convince him to get a 3.4. fresno isnt that far for a drive, well for me its not.
mike (loomdog)
Old Jan 15, 2002 | 05:17 PM
KED85's Avatar
Actually, I'll help ya this way.
Call 323-587-3144, ask for Marty & tell him Karl with a 1985 Firebird that go a 3.4 V-6 from ya told me to buy one from you, too!.
I paid $800 for my 40K motor.
He has PLENTY of them. He can deliver, also.
And, you said Fresno not that far away.......
When ya come pick it up, I may be available for a look see at my ride.
I just took FastRS for a ride in my swap job yesterday, we raced a 80's Camaro, probably close to 100MPH. Luckily, I didn't get caught!
Old Jan 16, 2002 | 02:21 AM
loomdog32's Avatar
Car: 82 Camaro Z28
ill look into that.. if i can get some of my old stuff sold, it wont be a problem. my money source doesnt want to put out anymore. do they have rebuilt 3.4s??? thats the route that i would end up going. anyhting cheaper then the gm performance parts 3.4 ht at $2k (also its not cali smog legal. damn 49 state stuff).
mike (loomdog)
Old Jan 16, 2002 | 09:48 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
KED got his to pass cali emissions........
Old Jan 16, 2002 | 10:15 AM
KED85's Avatar
loomdog,
READ MY THREAD and send me an email for any question!
Honest, you'll win!!
IF NOT, I'LL PAY FOR YOUR EMISSIONS DOWN HERE IN LA AREA!!
Call Marty and ask him.
He goes real low for high milage engines.
I paid for a low milage just broken in 3.4
I have atleast 100K HAPPY MOTORING MILES AHEAD OF ME without a rebuild.
Old Jan 17, 2002 | 07:23 PM
loomdog32's Avatar
Car: 82 Camaro Z28
ok.. i have read it many times and another one thats carbed based in a 82 firebird.
http://ken.lowrance.com/1982Firebird/1982_Firebird.htm
the 3.4 i was talking about is the gm performance parts engine. my grandfather (the person who is buying the engine) will only buy a rebuilt engine. if it was me and my money it wouldve already been done and i wouldve done exactly what u did. its been one giant nightmare for me cuz of that. im gonna try to sell some of my old stuff on ebay and get enough money that way to get the engine and avoid the nightmare im having now.
Old Jan 17, 2002 | 07:35 PM
KED85's Avatar
Good luck finding rebuilts!
New is $1700.
Hey it's his money
Old Jan 17, 2002 | 08:35 PM
Engine: 5.7 / 7.4
From AZ: rebuilt 2.8 w/core ~ $1500
New 3.4 from GM ~ 1700
is sure he wants a rebuild
did some calling around here, about 4 places have 3.4s, & the place w/ the 28K motor droped the price to $650. And i'm STILL waiting on my other W2
Old Jan 19, 2002 | 10:31 PM
loomdog32's Avatar
Car: 82 Camaro Z28
i can get a rebuilt 2.8 w/ core here for $800. the only way i would stay with a 2.8 is forged bottom end (perp for a sc or turbo) bored .30 over. crane cam above the 2030. full roller rockers. stiffer springs. ported and polished heads. ported intake. balanced and blueprinted.
i do have the option of dropping in a used 2.8 rite now. it would be a very temp solution. but it would be a solution.
Old Jan 19, 2002 | 11:11 PM
KED85's Avatar
Want to get a 3.4 for $800?
Come on down to LA.
Get from the same guy I got mine from.
He can deliver, also!
$800 for a 2.8?
Gotta be kidding.
I'm hoping to be given one, a running block
Cleotiz
Jan 6, 2018 08:56 PM
Digs_do_it89
Aug 30, 2015 10:24 AM
E Rod
Aug 28, 2015 05:17 AM
86Base
Aug 8, 2015 01:34 PM
92projectcamaro
Aug 6, 2015 01:20 PM
