What did you do to your v6 today ?
Old Apr 16, 2018 | 06:05 AM
  #251
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Re: What did you do to your v6 today ?
Man you've been busy, I changed the oil and filter, for some reason at the same time its decided to not start right away , way too much cranking for my liking , not sure what's happening , it runs fine ???? Any clues let me know ?
Old Apr 16, 2018 | 06:44 AM
  #252
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Thought I'd add I think it is not oil change related , I remember having difficulty starting literally just before hand. It cranks forever but dosnt even try. Then fires. I can here the fuel pump working .
faulty clutch switch ? maybe I should check quick.
Old Apr 16, 2018 | 08:26 AM
  #253
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Clutch switch stops it turning , it's not that , found no spark coil seems ok , gota take dizzy apart and have a look
Old Apr 17, 2018 | 08:58 AM
  #254
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Think pick up coils dead, really really high resistance, looking for new dizzy
Old Apr 21, 2018 | 06:07 PM
  #255
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Transmission: THM 700R4
So, not what i did today but the last week. I finally installed the S-15 trans in the firebird after 9 months. Drove it 2 1/2 states (365) miles home and all is back to normal so far so good. Now i have to go replace the thermostat.
Let the fun begin!
New torque converter !
S-15 trans 40k miles changed tail housing, detent cable and mount.
Installed!!
If you ever have to change the detent ( kick down cable).
kinda like the lowered rear look when it's up.
After install and drove 365 miles home. i'd say it works!
Old Apr 22, 2018 | 01:49 AM
  #256
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Nice job mate she looks awesome, I really like those wheels on the non gfx car.
Old Apr 24, 2018 | 09:58 PM
  #257
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Well went and bought thermostat changed it and when tightening the thermostat housing it cracked. going tomorrow to get that too...one part at a time....lol
Old Apr 28, 2018 | 10:07 PM
  #258
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Well thermostat and new housing in and readjusted kickdown cable it's back 100% again yay!!
Old Apr 30, 2018 | 01:35 PM
  #259
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Cool, now let's see it tare up the tarmac
im waiting for the postman.........
Old May 1, 2018 | 07:46 AM
  #260
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
I received and fitted the new dizzy, fired her up, she's back , just need a timing light , spitting a bit of fuel and not quite right . Bit noisey under the 4&6 rocker .
Old May 2, 2018 | 02:02 AM
  #261
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
No new pics, but I washed it and drove it to work tonight. Running beautifully!
Old May 2, 2018 | 02:39 AM
  #262
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Originally Posted by ktthecarguy
Hi there,
Jealous
Old May 3, 2018 | 04:58 PM
  #263
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Well car is still getting too warm for me went to flush system since all but radiator new. get it up to temp and fan doesn't kick on. turn heater on still nothing...found my issue. Before it was working but guess not well enough. Another thing to fix.
Old May 7, 2018 | 06:35 AM
  #264
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Timed it up 11° , new plugs, drives ok still coughing and spluttering but no ses light which I find a little strange , maybe I need to investigate the noisey under rocker cover 4&6. ??????
on my car it means pulling the intake which sucks
Old May 7, 2018 | 01:45 PM
  #265
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Had fan issues replaced relay, coolant sensor, thermostat, and housing...didn't help...traced wires no problems. it was the ecm swapped it and all good now finally!
Old May 7, 2018 | 02:14 PM
  #266
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Dam. Change the ECM for the fan to work ! 😱
Is the old one repairable ?
Old May 10, 2018 | 01:02 PM
  #267
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
My noisey rocker seems to be the rocker sitting against the pcv chamber on the rocker cover , there's a wear mark on it !
Old May 12, 2018 | 06:35 AM
  #268
On Probation
Drove it to work tonight, in the rain. But I drove it! Still more fun the the minivan.
Old May 15, 2018 | 02:10 PM
  #269
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
I need someone to come put on my ported heads for my 3.4 turbo. still building the turbo piping, and I have these bar ported iron heads just laying in my garage.
Old Jun 4, 2018 | 04:06 PM
  #270
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
I am not sure if it is.
So lately been having trans issues from the trans i just put in. Jacked it up and rear shaft seal was leaking...changed it topped off the trans fluid and all is good again.
Old Jun 5, 2018 | 09:43 AM
  #271
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Drove to the shop with a busted clutch master. Cyclinder , very tricky, clutch re engages if I keep my foot down so I have to pop it out of gear and lift my foot each time. Interesting !
Also started on a new intake design since I have two broken upper manifolds , I will get one of them fixed ......
Old Jun 6, 2018 | 02:11 PM
  #272
Kishan's Avatar
Car: 1989 Trans Am
Engine: MPFI 2.8L & 3.4(3500 hybrid)
Transmission: Manual
Bought this gem about a week ago, couldn't refuse the price + it has a electronic dash! Finished putting in the tranny, reverse let go.
Not a fun job replacing the tranny on the floor -_-'
Few more things to do b4 its road worthy but I'll get there soon. 88 bird
Old Jun 11, 2018 | 06:11 AM
  #273
On Probation
Took it to the first car show this season, Wilson Barn Show in Livonia MI. Sorry no pics, forgot to take the camera. Besides, it was raining. But still, first show! Several people looked, and a few remarked how they haven't seen a V6 Camaro in years.
Old Jun 19, 2018 | 04:32 AM
  #274
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Fitted new clutch master . Hopefully I'll get to drive it now 😂😂😂😂
Old Jul 15, 2018 | 05:05 AM
  #275
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Fitted a wonder bar. Omg what a difference ! If you don't have one. Get one. Period. I didn't realize how floppy the front end was lol
Old Jul 15, 2018 | 04:45 PM
  #276
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
Well ever since i put in the used trans i have had trans overheating problems. Replaced shaft seal, trans lines, radiator, thermostat and housing, new fan motor, all cooling sensors and relays, deleted a/c condenser, and added external trans cooler ( later today ). Hopefully this will fix the issue. Have not started it since new radiator.
Old Jul 16, 2018 | 02:35 AM
  #277
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Was that meant to say trans overheating problems? How do you know when your transmission is cooking ? In my manual it's fairly obvious but I'm doing the changes , just wondered.
Old Jul 26, 2018 | 05:12 AM
  #278
On Probation
Drove it to work tonight, stopped at McDonalds, was told by the cashier, "Wow, nice Corvette!" (um, it's a 1986 Camaro SC.)
Old Jul 26, 2018 | 10:11 PM
  #279
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Replaced so many vacuum lines I lost count.
Old Jul 27, 2018 | 10:00 AM
  #280
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Ktthecarguy
never herd someone say that about a Camaro, but i have had it on my Firebird , which is not too far removed from the c4 .
Old Jul 30, 2018 | 11:23 PM
  #281
T-Mack98's Avatar
New here but i recently threw on some pace setter headers on my v6 (2.8). Straight piped it all the way back and since money was short, and because I didn’t want to wait for a glass pack to come in the mail i just threw on a magna flow rumble exhaust for the time being
Old Jul 31, 2018 | 09:56 PM
  #282
Sean's Garage's Avatar
Wait why would you intentionally put in a v6?
Old Jul 31, 2018 | 11:52 PM
  #283
On Probation
Who are you asking?
Old Aug 5, 2018 | 02:48 AM
  #284
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Drove to friends for dinner , drive home late roof off , see tons of stars in the country, stopped a bit looking out the top, nice cruise.
Old Aug 5, 2018 | 04:25 AM
  #285
knightinblackar's Avatar
Car: 1984 Firebird S/E
Engine: 1985 2.8 MPFI
Transmission: 1985 T5 5 speed manual
Axle/Gears: 3.42/4.03
Only went and won a trophy at a car show we were invited to! Still in shock!!
Old Aug 6, 2018 | 03:09 AM
  #286
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Congrats
Old Sep 2, 2018 | 10:57 AM
  #287
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Fitted new headlights, old ones were rusted out, just trimmed rear springs and bump stops .
Old Sep 3, 2018 | 03:45 AM
  #288
On Probation
Hi there,
I replaced the fuel injectors with Southbay ones. Now it bucks and sneezes and farts and hesitates. Worse than before. And strong smell of fuel. It started to do some of this before I replaced the injectors (which is why I replaced them!)
I can't find any leaks, but strong fuel odor when idling, and really poor gas mileage. Can anyone give me some pointers to look for?
Old Sep 3, 2018 | 04:10 AM
  #289
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Is it at all temps ? Maf ? Disconnect see if it runs better , any codes ? Bad spark ?
Old Sep 3, 2018 | 05:49 AM
  #290
On Probation
Thanks I'll try disconnecting the battery and see if it runs any better. I just got the injectors in a couple days ago, not much driving since then, so I don't know every scenario when it runs bad. I get error codes for EGR and A.I.R. but... I removed those! So no surprise I get error codes for them.
MAF is new, and yes it was causing cold-start problems before, but that has been cured.
I will report back after trying the battery.
Old Sep 3, 2018 | 06:01 AM
  #291
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Haha suprise to me, I've removed them and never get codes
Old Sep 3, 2018 | 09:53 AM
  #292
On Probation
well, disconnected the battery for and hour, connected it, and... no change. Still idles rough. then...
SUCCESS!!!
I was looking for fuel leaks or puddling fuel, because it still stank, when I noticed one of the spark plug wires (high tension leads to you, zs&tas) was touching the header. I thought, maybe it's sending the spark to ground. Same wire also touched another wire. So I got a couple zip ties and a leftover plastic wire loom, and Got the wires to stop touching and rubbing. Took it for a test drive, and BINGO! idles smooth, plenty of power, no hesitation and snorting, and no more fuel smell. Probably because it is burning properly.
Thanks for the tip, zs&tas, if I hadn't been snooping around in there, I might not have spotted the wiring problem. Cheap Skate is back to being fun to drive. Time to take the kids for a cruise and find some lunch.
Old Sep 3, 2018 | 10:16 AM
  #293
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
bad spark then ! Happy cruising 😁
Old Sep 8, 2018 | 05:42 AM
  #294
On Probation
Drove it to work last night. Smooth as silk.
Old Sep 30, 2018 | 02:49 PM
  #295
88Birdman's Avatar
Car: 1988 Firebird
Engine: 2.8
I can tell by the sound the trans makes when you first move. Usually a higher pitch sound. In other news trans not overheating anymore because its garbage. lasted a whole 3 months. So found another used one....putting #3 in this week. Oh and broke my door handle again....I'll update when it's done.
Old Oct 1, 2018 | 01:11 AM
  #296
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
That sucks , maybe worth getting it reconditioned ?
Old Oct 9, 2018 | 04:53 AM
  #297
On Probation
Hi there,
Drove my car again tonight. Purring nicely, good tunes on the radio, nice temperature outside. Can it get any better? Yes!
I was driving down the main road to work, timing the lights just right so I hit all green lights, when this Caddy comes up behind me. He wanted in the fast lane, where I was, and was zig-zagging through traffic to beat me. He finally got ahead of me, but didn't time the light. He hit the brakes to stop at the red light, while I held back a little, and blew through the green light. Boy was he mad! I could HEAR him coming up behind me, and he was zig-zagging through traffic again, trying to blow my doors off. He finally got by me, and as I watched his taillights, i think it was a CTS-V, basically a four-door Corvette, I thought, that guy paid more for his TIRES than I paid for the whole car!
That put a big smile on my face.
Old Oct 9, 2018 | 06:23 AM
  #298
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Hehe, I have seen something like this many times now, my crowning achievement was going round a corner the BMW X5 trying to follow me went in the ditch. I wasn't even in a thirdgen lol
Old Oct 19, 2018 | 02:08 PM
  #299
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Daily driven this week. Bought some metal to fab up my new intake .....
Old Oct 22, 2018 | 01:57 PM
  #300
Lost one of the alternator bracket bolts apparently. No idea what should be in there either, and I'm in the UK so finding one is going to be a nightmare! Can't run the car until its fixed as its shredding the belt
