Running temp?
Car: 1987 Firebird
Engine: 2.8L V6
Running temp?
hey guys, so I’ve been doing so reading on the running temp of the 1987 2.8 MPFI v6 and what temp the fans turn on. Idk the running temp but I’ve read the fans turn on at around 235? That seems a bit high to me. Can anyone confirm or deny this I really need the info!! Running temp? And what temp the fans SHOULD turn on at? Thank you so much!
Car: 1998 Camaro Z28
Engine: 6.0L
Re: Running temp?
That's correct, fan comes on around 235. Factory running temp is around 210-220 with a 195 t-stat. I used to run a 180 t-stat to keep it a bit lower. Seemed to run a bit better too.
Car: 1987 Firebird
Engine: 2.8L V6
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Running temp?
If you are worried you can get a SW555 (89 turbo trans am) fan switch 211F try rock auto and a 180 stat. They should keep everything nice and cool. I would not go any cooler than that also don't put the fan on temp too close to the thermostat.
Car: 1987 Firebird
Engine: 2.8L V6
Re: Running temp?
I just looked I couldn’t find anything with the single one blade connector
Car: 1987 Firebird
Engine: 2.8L V6
Re: Running temp?
Here are the factory switches
https://www.rockauto.com/en/catalog/...an+switch,4312
like I said the 89 turbo 3.8L trans am has a direct bolt in lower temp switch
Car: 1987 Firebird
Engine: 2.8L V6
Re: Running temp?
I see what your saying but my connector is different it’s this onehttps://www.summitracing.com/parts/smp-ts76
Re: Running temp?
Sounds like you have the wrong connector. What you posted only controls the gauge not the fan. Either you are looking at the wrong sensor or someone modesm your car a bit because getting the right one was too difficult for them
Car: 1987 Firebird
Engine: 2.8L V6
Re: Running temp?
Ahh okay I know which one to look at now, and if you know what does the one I was looking at di if you don’t have a gauge only an “idiot light”
Re: Running temp?
If you dont have a gauge then all it does it turn on the idiot light
Note how some say gauge or light
https://www.rockauto.com/en/catalog/...+/+sensor,4748
99transamgirl
Jun 28, 2008 02:19 PM
camaro89rs355
Sep 6, 2002 12:13 AM
BLACK Z
May 1, 2001 08:34 PM
Biochem
Apr 18, 2001 12:45 PM
