TPI 2.8L/3.4L to Carburator
1987 Firebird 2.8L V6
Several years ago and about 17,000 miles, I replaced the 2.8L (173cid) short block with a stroked 3.4L (207 cid) from A.R.I in Kansas City (direct swap for 2.8L). At that time, I had the heads rebuilt, installed a Crane Street Performer cam, roller rockers, double roller cam chain, reduction pulleys, B&M transmission kit. Ran great until the fuel injection problems hit.
This summer I converted my 3.4L TPI to a Carburetor. The car runs like never before. Stomp on the line, and burn 'em down. Stomp at 20MPH, and she starts spinning those Goodyears. Second and third gear shifts chirp. WOT lays you back in the seat nicely.
With all the changes I have made, I am guessing right at 190HP, but have not dynod yet. if anyone is interested, I have documented the changes I made here:
https://gmv6-tpi-to-carb.com
Car: 1985 Firebird
Engine: 3.4 turbo
Re: TPI 2.8L/3.4L to Carburator
I had a 3.4 built by ARI too , but I didn't see an option for a stroked engine. Did you get this custom ordered?
If you look at their web site, http://www.engine-parts.com/GMV6/gm2834stkr.html
Pro-Builder® GM 2.8L Stroker Engine
Available in 3.1L and 3.4L Displacements
Car: 1985 Firebird
Engine: 3.4 turbo
Car: 1985 Firebird
Engine: 3.4 turbo
a post on fullthrottle v6 says technically it is 204.8in. I'm not trying to be smart, just wondering if you had it over-bored or not.
Car: 1985 Firebird
Engine: 3.4 turbo
you 've don'e what I almost did a while back. I had megasquirt put on my car but the intake manifold for MPFI just doesn't flow well. I only dyno'd 110 whp and 160 ft lbs STD corrected on a dynocom dyno.
If you got 110, you lost power. All I can say is my engine now has way more power and is more responsive than before. It's not even close. If you read the write up, I not only put a carb on, I changed intake, ignition, cam, roller rockers, reduction pulleys, cat back and used a carb matched to the size of the engine.
Car: 1985 Firebird
Engine: 3.4 turbo
Yes I had a comp 260h cam, 1.6 roller tip rockers , and pacesetter headers with no cat. idk how I dynod 110.
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Car: 1998 Camaro Z28
Engine: 6.0L
If you consider a loss through the worn drivetrain, plus only guessing what the engine was making at the flywheel, it's entirely possible that 110 is correct. Especially if there was no tune, or an improper tune. People almost always over estimate what their dyno numbers are, and then are disappointed or cant understand why they only dynoed XXXhp.
Car: 1985 Firebird
Engine: 3.4 turbo
Yes dr. dave. however, my car was dynotuned with megasquirt ii. I believe I might have had a misfire going on, and my old muffler was probably clogged. But it did make a good torque number.
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
did you have any problems with that ?
is there a stroker crankshaft for the 3.4 available?
Car: 1985 Firebird
Engine: 3.4 turbo
camshafts work regardless of the crankshaft. no real such thing as a stroker camshaft. and there are plenty of cams available for these engines.
polygaryd
Feb 13, 2007 08:52 PM
