Stick with TPI or go for carburator?
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
Sometimes part of me just doesn't want to deal with the ECM. Has anyone gone from TPI to a carburator? Do you have to run a new fuel line, or is it even possible to run a carb with the stock electric fuel pump and an adjustable fuel pressure regulator? I don't know jack about afp regulators, and I don't know if it's even possible to get the psi down that low. Doesn't a carb run at about 8 psi? If it is possible, I was thinking that I would get a vacuum advance distributor. The plus side is that it would be cheaper for an intake, but the downside is that I'd have to deal with an effin carb. Any thoughts?
Engine: SBC 350
Re: Stick with TPI or go for carburator?
Forgot to add that I'm amidst building a motor, so I have options. It's not like the motor is in the car and I'm gonna be screwing around with it. It's gonna be all set up, whichever route I decide to go, before it goes in the car. I've already got a Comp 306 cam, and a set of ProComp heads (2.02/1.60 190cc intake runners) should be here by Monday.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You'll be better off in the long run staying TPI, but that may not be the best for performance. That cam is way too big for a TPI car. Consider a stealth ram.
Engine: SBC 350
If I go with MPFI I'm going to go with the hsr.
Engine: 4++,350 & 305 CIs
EFI gets my vote.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I vote carbureted. I converted my car over. Easy to make awesome power on the cheap, and easy to find parts.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
https://www.thirdgen.org/carbswap
http://5finger.8m.com/tpi2carb/tpi2carb.html
Commonly done on here with a Mallory #4309 AFPR or similar unless you want to drop the tank to install a carb pump
Sanjay
Aug 12, 2015 03:41 PM
