1992 firebird 3.1 help
Old Mar 27, 2019 | 11:50 AM
Dustin Hinton's Avatar
Hi guys, I have a 92 firebird v6, I did a fuel pressure test on my car and its getting 39 psi, and it is getting spark, sometimes I can get it started for about 8 seconds then dies, it runs rough, I think there is a weak fuel pump, I don't see how it can stay or start running on 39 psi, I use to once a week let the car run for 10 mins as it is not good to let it just seat there, when the fuel got low I would get a gas can and put 5 gals in, this went on for about 5 weeks, after a while when I started the car it run rough, while I replace the fuel filter then It just got worse and wouldn't start, I hope this made since.
Old Mar 27, 2019 | 09:13 PM
Drew's Avatar
Re: 1992 firebird 3.1 help
Original fuel injectors? 39PSI is close enough. Stock Multecs in 2019 would be a lot more likely failure.
Old Mar 28, 2019 | 03:53 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Is the car being driven ? Or sitting? Seriously they need to be used to keep them going , a full tank of gas and injector cleaner and a good run , it might just clear up . Is the computer throwing any codes ?
Old Mar 28, 2019 | 10:14 AM
I change the plugs and wires, everything else is stock, the ecm is not throwing any codes, the car is been sitting I don't drive the car
Old Mar 28, 2019 | 01:35 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I had a similar problem. It was the injectors. I got some from Southbay and it started up and ran fine after.
Old Mar 29, 2019 | 08:31 AM
Are there any posts on here that tells how to change the injectors, since no one else is saying anything more
Old Mar 29, 2019 | 12:54 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
It's pretty easy. You just take the top half of the manifold off, 8-10 screws? take the air intake off the TB, and I think it's 4 screws for the fuel rail. I didn't even disconnect the feel and return lines to the rails, I just flipped the rail assembly over to the DS fender and rotated the injector clips.
Old Mar 29, 2019 | 07:04 PM
Thanks, what's the site you got your injectors?
Old Mar 29, 2019 | 09:38 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
South bay, a site supporting vendor. If you tell them you are with TGO you get 10% off. Link is on the side bar --->
Old Mar 30, 2019 | 11:10 AM
i got the intake half off, how does the injectors come out?
Old Mar 30, 2019 | 12:23 PM
maroe624's Avatar
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Piece of cake .I have done it so many times. I can have it tore down to the manifold in less than 5 mins flat. What I do to remove injectors is not even bother with the fuel lines. Just leave them connected and remove the 2 bolts holding the fuel rail down and simply flip the fuel rail over with lines and all towards the driver side and remove injectors that way. I can swap injectors in 10 mins flat.
Old Mar 30, 2019 | 01:16 PM
Sounds good now how does the injectors come out
Old Mar 31, 2019 | 06:59 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
There are little clips that you have to 1/4 turn in the rail to get the injector out. I mentioned that in my other reply.
davidopliger
Feb 3, 2025 09:30 AM
mikeye90
Sep 4, 2008 08:46 PM
1992camarors
May 11, 2006 03:33 PM
chuck6860
Jul 23, 2002 09:36 AM
Bulldog92
Jul 17, 2001 10:22 AM
