Help me breath a little better :-)~
Old Jan 9, 2002 | 04:30 PM
WaynesRS's Avatar
My oil cap on my valve cover is leaking . Does anyone have a K&N valve cover breather in this ? Was curious as if they made one and if they do what is the part number ? Thanx guys !
Old Jan 9, 2002 | 09:04 PM
WaynesRS's Avatar
ttt
Old Jan 9, 2002 | 09:39 PM
BitchinRS's Avatar
Yeah they make one, but you have to watch out for the size and make sure it fits. Some are huge. Also grab a stock one from the scrap yard the next time you go. If you have to pass the emissions test they will take one look at it and fail you just for that.
Old Jan 9, 2002 | 10:33 PM
WaynesRS's Avatar
Thanx bitchin rs ....Does anyone know of the part number ?
I have fuel injection , so I wanna make sure it clears the plenum .
Old Jan 10, 2002 | 12:53 AM
BitchinRS's Avatar
I don't have the part number any more. I just went to the parts store (Kragen, AZ, and other should have them in stock) and got one that I thought would fit and bought it. Once I was trying to put it in I found that the heat shield that goes half way around it was sticking out a little to far. So I banged a dent into the side of the heat shield that was rubbing and it went in just fine. You can't even tell I hammered unless you take it off and look that side.
Old Jan 10, 2002 | 10:06 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've got a Spectre oil cap; anodized blue aluminum on my car- just like my rad cap, dipsticks, and p/s cap. It passes emissions, and won't interfere with your PCV system like a breather would.
Old Jan 10, 2002 | 03:08 PM
BitchinRS's Avatar
Yup, that's why you wont pass emissions with the breather. It lowers the crank case presure. Once I get my engine bay cleaned I going to swap it for one with a bit more collor.
Old Jan 10, 2002 | 08:08 PM
WaynesRS's Avatar
Will having the breather make my car run bad or make it do anything I don't want it to do ? ...They dont even look under my hood when they inspect my car .Thanx guys , Wayne
Old Jan 10, 2002 | 10:00 PM
BitchinRS's Avatar
It just lets the crank case breath. This keeps the PCV system from function as the EPA would like. Some say that a oil breather cap will increase the life of the engine, but I haven't been given a good explianation on how.
but no it wont make your run like crap or anything.
Old Jan 10, 2002 | 10:15 PM
WaynesRS's Avatar
Thanx again !
I just like the looks of them , I dont know what it is . Yesterday I put my wire separators on my accel plugwires , looks so neat and nice .I just like the wires being straight lol I just thought I might as well get me a breather sence my cap is crapped out .Dress it up a little ya know .
Old Jan 11, 2002 | 01:25 AM
Camaro_hunter_d's Avatar
Originally posted by BitchinRS
It just lets the crank case breath. but I haven't been given a good explianation on how.
It lets the internal pressure of the crank case bleed off(equalize with the outside) at will or basically all the time the outside Barometric Pressure will be only slightly lower then the internal crankcase pressure. It helps prevent the build up of gas pockets, oil "clouds" and all pressure pockets that we know when the PCV system fails it blows the rings out and locks the motor up!.
....Less crankcase pressure means better sealing rings, no reverse pressure tring to push them into the grooves and cause blowby, no matter how slight. Or even worse tring to bend them in thier groves between the piston and the groove.
The crankcase creates pressure by its rotating movement, the sloshing/flying oil only makes it worse.
Help that explained it.
Old Jan 11, 2002 | 01:40 AM
BitchinRS's Avatar
Thanks CHD. that clears it up for me!!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
PurelyPMD
May 5, 2016 04:57 PM
Blade3001
Aug 24, 2001 10:25 PM
GTA-Force
Jun 1, 2001 06:01 AM
Pino91Formula
Jan 29, 2001 02:05 PM
