ECM Removal
Old 06-08-2021, 05:14 AM
Adrenaline1's Avatar
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
ECM Removal
Since i cant get anywhere with chip tuning i may try another route. If im removing all of the emissions equipment and NOT running the stock computer controlled carb do i need the ECM for anything? Based on what ive read its completely useless unless youre running the stock setup but id like to verify that i wont run into any issues half way through this project. Thanks
Old 06-08-2021, 07:36 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ECM Removal
Mc solenoid for idle won’t work as well as timing control. Why not leave emissions intact?
Old 06-08-2021, 07:44 AM
Car: 1982 Firebird
Engine: 2.8 N/A
Re: ECM Removal
Neither of those are a concern since i can easily swap everything over to a traditional carb and distributor setup. The emissions system is completely shot. Literally every single part of it is broken on the car and theres absolutely no way im going through the hassle of replacing it and getting it to work since its over complicated and useless. On top of that i have mod plans that simply wont work well with the stock setup anyway.
t-roy383
10-18-2011 08:06 AM
zevans08
12-09-2008 02:27 PM
HiPerf_Chevyman
07-06-2007 03:43 PM
summit56
06-23-2007 11:49 AM
Quick Reply: ECM Removal
