Need help with vaccume hose replacement
Car: 1992 RS Camaro
Engine: 3.1V6
Axle/Gears: stock
Has anyone with a 3.1 V6 engine ever replaced the vaccume hose going to the port that sits below the alternator ?
I don't know what this vaccume port is but Im having trouble getting a new replacement hose , pushed on to it . It's a 5/32"
hose, I tried long reach pliers and hose pliers with no luck.
Also, a photo of the hoses where they connect at the back of the plenum will probably be needed so I can connect this correctly.
A lousy mechanic redid my vaccume hoses and connected them wrong and left the 5/32" hose hanging down towards the oil pan.
Thanks for any help you can give me.
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Need help with vaccume hose replacement
What is vaccume?...
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Get aset of these
https://www.harborfreight.com/3-piec...ers-37909.html
5/32 Vacuum line can be bought in bulk
https://www.google.com/search?q=5%2F...hrome&ie=UTF-8
Car: 1992 RS Camaro
Engine: 3.1V6
Axle/Gears: stock
I thought the same as you and bought the HFT hose grip pliers.
They are the wrong size, that set includes 3/8" , !/2" & 3/4" pliers.
The hose is 5/32' and slides through the pliers.
Tomorrow, I'll try and wrap the pliers with tape to make them smaller.
I already have the new hose , from Autozone.
