V6 3.1 Throttle Position Sensor Gasket
Old Feb 27, 2024 | 03:57 AM
aycaramba's Avatar
Car: '1991 Pontiac Firebird
Engine: LH0 - V6 3.1
Transmission: TH700R4 automatic
Hey Guys,
I need help in finding the right replacement for the TPS Gasket. As far as I can see, it's leaking, and I want to replace it. Now I looked for "firebird 3.1 v6 tps gasket" but can't seem to find anyhting about that. I have a picture attached.
regards
Old Feb 27, 2024 | 09:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: V6 3.1 Throttle Position Sensor Gasket
There isn't a gasket for the TPS, it mounts over the end of the throttle shaft. A dry area.
RBob.
Old Feb 27, 2024 | 10:08 AM
aycaramba's Avatar
Hi Rbob, thanks, but I could see the gasket, after I removed the TPS. I forgot to take a picture. It looks like a sponge rubber O-ring.
Do you have an image showing the TPS location from a 3.1 V6?
Old Feb 27, 2024 | 10:09 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Lt1 uses a sponge . But if you have a major vacuum leak there might look for a used Throttlebody. Even new the shaft to housing had slight leaks.
https://www.motorcityvettes.com/engi...-lt1-1995-1996
Old Feb 27, 2024 | 10:47 AM
aycaramba's Avatar
The sponge for the LT1 looks exactly the same.
Old Feb 27, 2024 | 11:05 AM
Engine: Lb9
Transmission: M20
If you look on rock auto looks like same part number for lt1 and 3.1 tps. I just don’t think it’s a item sold separately.
Old Feb 27, 2024 | 03:29 PM
aycaramba's Avatar
Could you please send me the link showing the lt1 gasket. I have trouble finding it. Thanks.
Old Feb 27, 2024 | 03:59 PM
Engine: Lb9
Transmission: M20
It’s black here but probably just to keep the tps clean or gp Sorensen 97-3028
Old Feb 27, 2024 | 04:00 PM
aycaramba's Avatar
Thanks!
Old Feb 28, 2024 | 07:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
What is the orange 'stuff' leaking out from behind the TPS?
I guess this isn't really a Firebird 3.1l engine?
RBob.
Old Feb 29, 2024 | 03:05 AM
aycaramba's Avatar
Thats a sponge rubber gasket, sitting right behind the TPS. As far as I can tell its a T-Code V6 Engine with 3.1 Liter in a Firebird from 1990. I can take some fotos afterwards. I know that the 2.8 litre engines have a different throttle-body.
dbrochard
Jun 29, 2015 02:20 PM
SageMoonblade
Sep 13, 2009 09:13 PM
Nocturnall
May 11, 2005 11:34 PM
