86 2.8l Wont start
86 2.8l Wont start
Hey yall,
I have an 86 2.8l MPFI Camaro that won't start and I'm really stumped on this. I'm getting spark at all cylinders, getting fuel, engine is cranking, but no start. I'm fairly certain I have compression and nothing has been done to the timing since it last started a few days ago. Voltage is reading 12.4 in accessory and around 10.4 while cranking. Let me know if some of yall could help me out here.
Car: ‘87 Base Firebird
Engine: 2.8 V6
Re: 86 2.8l Wont start
Any codes? I can grab some diagnosis pages out of the 88’ Firebird service manual if you want the “official” diagnosis procedure. Some stuff wouldn’t apply to your 86 but the engine stuff would be identical.
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Hey yall,
Shoot some brake cleaner into the air intake and then try to start it. If it fires momentarily, you have a fuel issue; if not, you likely have an ignition problem.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Have you checked timing? Are you certain youre getting spark when need or just intermittent spark? My 1st 87 Firebird with the 2.8 had an issue with the pickup coil in the distributor. It began as an intermittent issue then one day stopped running altogether.
I haven't touched anything with the timing at all but I suppose it could be that, but if so that may be out of my range of expertise. And I am certain all cylinders are getting spark, though maybe not at the correct times, but I can hear the car backfiring a bit when holding the gas while starting it.
Engine: LT1, L400
Edited to add this clarification,
This statement;
"If you haven't touched the timing (as in loosened the hold down bolt & moved the distributor)"
means; "IF YOU OR NO ONE ELSE HAS RECENTLY LOOSENED THE HOLD DOWN BOLT & MOVED THE DISTRIBUTOR"
And the bolt is properly tight as it's presumed to be, , , , ,
The timing doesn't just change on it's own.......
Engine: LT1, L400
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
This could be an indication that you're getting too much fuel. Check the fuel pressure regulator vacuum hose to see if it smells like fuel. You can further diagnose fuel issues with a fuel pressure gauge to see if it's holding pressure after key on engine off after the 2 second prime. You can try a WOT start to see if that improves the "attempts" to start. IIRC these engines also have a cold start injector that could be leaking. An erroneous coolant temp sensor that tells the ECM that it's colder than the actual ambient temp can provide too much starting fuel as well.
Thanks for the responses yall. Been busy the past few days due to the Holidays and what not. I should have clarified that the distributor was replaced about a year ago by the previous owner.
Car: 85 t/a
Engine: 5.0 tpi
had a similar problem with 86 2.8.. was getting spark but it was intermittent weak spark which i didnt realize at first, tried everything to fix the intermittent no start.. turrns out once i replaced the ignition coil all my problems were fixed. that's when i realized even though i was getting spark.. it wasn't strong enough.
I thought of that when I was going through the whole mess and replaced the ignition coil. Found out after that was that the distributor was 180 degrees out of sync from when the previous owner had replaced the distributor. Was a headache for me to figure out with my little experience. Runs right as rain now
