Can not get off distributor
Old Oct 11, 2025 | 05:35 AM
mikiman's Avatar
Hello. My 1990 3.1 V6 is leaking oil from the distributor shaft, and I want to change the O-ring, but I can't get the distributor out. I'll tell you how I did it to see if there's any mistake. I disconnect the battery. I remove spark plug 2. It should be plug 1, but access is difficult. I turn the crankshaft pulley until its large mark is on the large V-shaped mark on the bracket. There are two narrower marks on the pulley. I continue turning the pulley until the tip of the rotor points to where the spark plug wire 1 would go on the cover. I remove the wires, cover, and cable tie. Then I pull up the distributor and turn it counterclockwise. But it only separates slightly from the engine.
Old Oct 12, 2025 | 02:03 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Can not get off distributor
https://www.thirdgen.org/forums/tech...ml#post6573305
Old Oct 13, 2025 | 10:35 AM
mikiman's Avatar
Solved!!WD40 and a pair of desesperating hours. And finaly It s out. Thanks
mikiman
Oct 13, 2025 12:11 PM
Cesar12
Aug 8, 2024 07:05 PM
s10sbc350
Jul 5, 2013 06:55 PM
Camaro_dude92
Jun 11, 2008 04:03 PM
dmp7777777
May 14, 2006 11:10 PM
