its me again NO START!!!! :(
Old Jan 25, 2002 | 11:49 AM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
I've got a 91 Camaro RS (3.1 V6) auto TH700R4, it started up perfectly yesterday & now all of the sudden this morning it won't. It's about 50 degrees outside here in MD & the car is parked on a slight incline, so I tried adding a little bit more gas to it, but no luck.The motor keeps wanting to turn & it won't kick over. A couple of times it acted like it was going to start up, but it didn't. I have no idea what the problem could be....Someone please HELP!!!!
Old Jan 25, 2002 | 11:53 AM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Check your timming, fuel pressure, put some drygas in it could be condensation.
Old Jan 25, 2002 | 11:56 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Check the two posts below that kjrockz started. I'm gonna print them out and tackle my no-start this weekend.
Sounds like we got the same problem. It sounds like its gonna go but ugh, not quite. Tip- dont crank and continuously tap the gas. The backfire scared the crap outta me (and the cat).
Old Jan 25, 2002 | 03:19 PM
KED85's Avatar
Pull any easy to remove plug wire and use a paperclip to check for spark.
IF BRIGHT LIGHTENING WHITE, find another cause of no start.
IF BLUE-ISH WHITE, you've found your problem. Weak spark. Why it's weak, is another answer.
The darker the light/area to check this spark, makes your problem solving easier.
PS if you do backfire, you've got spark, also. BUT, maybe not strong enough to ignite the engine.
Your car should start up right away after a VERY FEW engine cranks. Don't kill/waste battery & starter
Old Jan 25, 2002 | 06:30 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
its 720 pm and im still working on it now its cold as hell out here!!
i changed cap and rotor but its now running so rough i cant even drive it and black smoke came outta the tail pipes(maybe it was from sitting for 3 days i dunno) but imma need any help i can get! i gotta go to my college class tomm. and i need to get it running
someone said my timing may be off now but i dunno how to fix that and i got a limited supply of tools i got only a ratchet set and a few wrenches and a few screw drivers that mostly suck
is it my timing ? and should i attempt to drive the car to a shop or will it die on me while i drive down the highway?
AAHHH nEeed help
Old Jan 25, 2002 | 07:06 PM
KED85's Avatar
Welcome to the world of a bad fuel pump.
Sucks.
Feel for ya, if it's that.
I just did mine, and it wasn't cheap nor totally easy.
Yea, sure can get cold there.
Use the buses, I had to.
You go to U of M?
or Towson?
Old Jan 25, 2002 | 07:41 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Damn, Another one Bites the dust.
Must be that time of the month,
all of our cars decided to PMS at the same time.
Mine should be over her period by next week, I let ya know what the problem was, maybe it will help.
You know all the feminine hygine products can get kinda confusing...
Old Jan 26, 2002 | 05:55 AM
Berlyn0963's Avatar
Car: 91 Camaro RS
how much is new fuel pump then?
and what kind of plugs do U recommend?
i bought some 99 cent bosch plugs but i havent put them in yet and what kind of wires U reccommend thats not too expensive?
im on real tight budget
thanx for help
Old Jan 26, 2002 | 08:06 AM
I Cant Drive 55's Avatar
I wouldnt go for a fuel pump yet.
If you are blowing out black smoke than you are running way too rich on fuel.
I would make sure the connections to your MAP sensor are good especially the vacuum line. A bad MAP sensor will cause the engine to run rich.
A bad fuel pump, you would not be getting enough fuel.
Old Jan 26, 2002 | 01:22 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
sooo ... umm ..
i also think it may be the timing
i really am not worried about the black smoke
it was only black for a min then it turned white then its was ok
but im worried about how it sounds and how ****ty its a runnin
it runs so rough that its undriveable the idle seems all outta whack and the engine shakes and it acts worse when i throw it in drive and try to go so for now its a 3,500 lb paper weight with oxidizing paint (on corner of hood ). . . it was once a beautiful car tho . . this really sux .. its the only car i got . .
Old Jan 26, 2002 | 01:32 PM
Camaro_hunter_d's Avatar
Before you go and change the timing make sure its out first. You want it between 12-13 degree BTC. GM says 10 but every 2.8/3.1 I have seen likes 12-13 MUCH better. Check timing. IF AND ONLY IF ITS OUT BY MORE THEN 3-4* then change it.
15mm bolt. base of distributor on passanger side. Go to sears and get there GM distrib wrench. I welded a 15mm short socket to it and it works great.
Old Jan 26, 2002 | 01:51 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
whats BTC? and do i gotta take off the Distributor cap to get to it ? hang on im gonna go outside now and see what Ur talking about its right outside my window lol brb :lala:
Old Jan 26, 2002 | 02:00 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
theres this long pole thingy sticking out next to distributor cap
its black and got kinda like groovy things on it > it looks like it may be used or turned for somthin' is that what Ur talking about Camaro Hunter D?
please help
Old Jan 26, 2002 | 02:53 PM
KED85's Avatar
Go to a local parts store, find an open shop manual for your car and read it. It has the pics of what is what. If it's wrapped, well, then break the wrap open and then read it.
I do that all the time & it's free!
Your car should not be outta proper timing setting because it "ran" before.
I think you've got bad gas in the tank.
Old Jan 26, 2002 | 03:17 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
i just got back from sears and got one o' those things call distributor wrench 1/2" or whateveer its like 8.99
i still dunno where the timing bolt is
help!!!!!!!!!!!!!!!!!!!!!!
i dunno how to fix it if its bad gas
its running soooooooooo rough
Old Jan 26, 2002 | 03:50 PM
GTRick's Avatar
what if the fuel injectors were dirty?
hey man where u live in MD? all the peeps in MD should get 2gether and check outeach others cars...
Old Jan 26, 2002 | 04:51 PM
ok. well you need a 15mm bolt opening. So take one of your old 15mm short sockets and have it welded over the bolt oipening in the wrench. Did you check your timing yet? What is it at?
The Distrib hold down bolt is on the passanger side at the base of the distrib out about an inch. Get a rag, put your hand down there and wipe it clean. Then look and feel around for the bolt head closest to your distrib. Thats the one you want.
BTC= Before top dead center.
Clean the timing tab on your engine. Look at the crank balancer and look at the tab the sits to the side and top of it.
Bad gas fix. Hmm get QUALITY NAME BRAND STUFF NOT WALLY WORLD (RAP. Get some gas dry, octane booster.
If you do not have a timing light GET ONE. You will need one for your own if you continue to own cars period. $25 for a decent one.
Do you KNOW you are getting spark? Is the batt low?
Old Jan 26, 2002 | 08:56 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
thanx for all your help
i appreciate it and i got i fixed finally
i had some of the wires crossed up on it and one was not on all the way and there was some duct tape on it too so it didnt help either
not too bad for my first time , 'eh?
N E wayz thanx again
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
