Dammit i wanna see some dirt on the K&N!
Old Jan 31, 2002 | 10:27 AM
86BIRD-MY FIRST CAR's Avatar
I have a 86 firebird 2.8 fuel injected and my replacement K&N air filter has not seen dirt yet. i know i did not spend $40 dollars for nothing
Old Jan 31, 2002 | 10:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'm confused; you didn't install it? Why would you want to see dirt on it? That means you have to clean it... or is this a joke and I'm missing it?
Old Jan 31, 2002 | 10:57 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i think he means he wants to make sure its doing its job as a filter
Old Jan 31, 2002 | 10:59 AM
no no i meant by installing the K&N i would expect more air flow and thus seeing more dirt on the filter which tells me alot of air is going through.....
Old Jan 31, 2002 | 11:00 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
maybe he just wants a piston w/a hot spot, crumbled piston after that, & an excuse to rebuild/replace the motor?
Old Jan 31, 2002 | 11:26 AM
KED85's Avatar
I hear ya.
I modified my air can lid on my 1985 Firebird.
Got nothing.
Opened the hood, adjusting up the hood bump stops, lowering the headlight assembly, finally it got dirty!!
It's not massive amounts but, I got in more air. That's all that mattered.
I've got another idea, up my sleeve, too.
Involves destroying a head light cover and cutting open under support bracing on my hood, for my mission.
Old Jan 31, 2002 | 03:27 PM
Hey KED, how do u adjust the hood bump stops(what are they by the way) and lower the head light assembly?
Old Jan 31, 2002 | 07:07 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
should have seen my K&N after I took my camaro out in the mountains
that thing was nasty
but so far 8000 miles on my K&N for my rx7 and can't even tell
Old Jan 31, 2002 | 11:05 PM
KED85's Avatar
Hood bump stops.
You've seen them!
Promise.
They are on the radiator core support, screw higher to raise the hood. Octagon shaped, one per side
I played with the nuts and such of the headlight assembly. I got it slightly lower.
I plan on cutting a large chunk of the hood support braces behind the headlight to allow more air into the box.
I plan on butchering a headlight door to provide more air, too.
I love pick your part!
Abubaca
Car Audio
Sep 24, 2015 02:33 AM
84redta
Sep 19, 2015 09:58 AM
Tylermcclinton
Sep 17, 2015 07:50 PM
64Chief
Sep 12, 2015 08:05 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
