Will 17 inch wheels work on a 3rd gen?
Old Aug 26, 2005 | 09:12 PM
superbm2day's Avatar
Car: 1988 Trans am
Engine: 305 TBI
I want to know if anybody has used 17 inch wheels on a 3rd gen. I know that they are supposed to work with a spacer or something! I just wanna hear if anyone has used em, and did they work well or not. I know I'll get an ear full from the old school guys but, damn it I dont care I want to put some vette wheels on my T/A. Thanks in advance, I know Ill get some good info from you guys.
Old Aug 26, 2005 | 09:18 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
size has nothing to do with it, you could put 20's on a camaro... it's all about offset.
Old Aug 26, 2005 | 09:20 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
People have put from 15 to 20 inche wheels on third gens.
Check the offset, backspacing.
Vette wheels need adapters... or spacers im im not mistaken.
Good luck
Old Aug 26, 2005 | 09:22 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
yup im running 17" torq thrust II's with 245/45/17 for tires. can turn the wheel all the way to the left and right with no rubbing.
Car: 1988 Trans am
Engine: 305 TBI
how do I measure the offset and backspacing?
Old Aug 26, 2005 | 10:50 PM
jimp2001's Avatar
Engine: LO3 305 TBI
here i found this with google:
http://www.high-impact.net/wheels/ho...ackspacing.htm
Old Aug 26, 2005 | 10:57 PM
Car: 1988 Trans am
Engine: 305 TBI
wow thanks!
Old Aug 26, 2005 | 11:28 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
I have 17x9 on mine with 285/40-17 on the back and 275/40-17 on the front
Old Aug 26, 2005 | 11:34 PM
Car: 1988 Trans am
Engine: 305 TBI
what kind of wheels? did u need the adapters or spacers. I see alot of them for sale, but which onesneed the spacers and which ones dont, another guy said he didnt need anything. Thanks for the help though.
Old Aug 27, 2005 | 08:22 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
I didnt need spacers... All of my wheels are zero offset, which on a 9 inch wheel is a 4.5 inch backspacing. If you use a corvette or 4th gen F-body wheel, you will need adapters
Old Aug 27, 2005 | 09:48 PM
Car: 1988 Trans am
Engine: 305 TBI
ok i get it now, thanks
Old Aug 30, 2005 | 02:08 PM
sshowell99's Avatar
Car: 1986 Firebird
Transmission: 5 speed
Running 17"x8" ROH wheels, no spacers required, dropped car down 1 1/2" all around, no problems, rubs just a little at full right turn. Can send pics if you want to see how they look.
Old Aug 30, 2005 | 03:33 PM
Car: 1988 Trans am
Engine: 305 TBI
Do they rub because you dropped it down? Id love to see pictures. What are the best aftermarket wheels to go with, brand wise? Im skeptical of buying any of the corvette reproductions off ebay or other places.
Old Aug 30, 2005 | 10:49 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
im running 17x11 in the rear with spacers and i need to roll the lips since they are cutting into the tire now. the inside on the wheel wheel needs a little tweaking also
Old Sep 5, 2005 | 08:07 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
roughskinjrz
17 what? 17x8 or 17x9 with what offset?
From the tire size you are running... I'd have to say 17x8.
But did you get the 4.75 offset?
I'm in the market for buying the same rims, but I'd like to buy rims and not paper weights.
Old Sep 6, 2005 | 09:23 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Check into SLP, I believe that they have 4th gen looking wheels but fit 3rd gens without spacers.
A 275/40R17 and 245/50R16 are the same diameter. Both tire sizes will work on either generation camaro given the correct wheel.
Old Sep 12, 2005 | 10:12 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
www.skulte.com/adapterfaq.html
A.
Old Sep 12, 2005 | 10:50 AM
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
sunbitz they are 17x8, with a 4.75 offset.
i love the rims, very nice.
Old Sep 12, 2005 | 05:11 PM
smokefan's Avatar
go to skultes website. he has the directions on how to measure the offset. then let andris know and he can get you the adapters
Old Sep 13, 2005 | 09:25 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
As I said above, SLP has great looking 17"x8" wheels which fit '82 thru '92 Camaros & Firebirds without spacers,,, they are designed for our cars,,, And now they are on special, $599 for a set of 4 ZR-1 style wheels.
Old Sep 15, 2005 | 10:29 AM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
So what offset would you look for in 17's?
I'm looking for 8" wide in front and 9" in back... Could I go 10" out back without modifying anything?
Old Sep 16, 2005 | 09:16 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
yes you can fit 10 in the back, this pic is a boyd wheel.
6 inches of back spacing in the back and 4 1/2 in the front.
Old Sep 16, 2005 | 09:17 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Axle/Gears: 373
Sorry forgot pic
Old Jul 16, 2019 | 10:40 PM
Julian Sargeant's Avatar
Will -5 offset in the back work ?
Old Jul 17, 2019 | 06:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Will 17 inch wheels work on a 3rd gen?
This thread is 14 years old.
-5 offset is meaningless without a width to work from.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
