bad front end shake
Old Apr 25, 2008 | 12:13 AM
badazz84camaro's Avatar
bad front end shake
i recently put the skinnies on the front of my car with the moroso ds-2 tires and i was driving last nite and hit a bump and the whole front of the car went into real bad tire shake until i slowed down. the front suspension is tight, is this an alignment issue?
Old Apr 25, 2008 | 10:30 AM
Re: bad front end shake
nobody knows?
Old Apr 26, 2008 | 10:54 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
maybe you hit the bump good enough to knock off a wheel weight and its not balanced. that what i would think of get them balanced, mine did the same thing a few years back
Old Apr 28, 2008 | 09:55 PM
c-u-later's Avatar
Car: 84Z28
Engine: 12:1 355
Transmission: fairbanks turbo350
u may of had a case of bumpsteer! I have had it happen at the drag strip about 100 feet out and its a freeky feeling. im going to try some solid tierod sleaves and have a drag race alignment done. some where i have the recomended specs.
Old Apr 28, 2008 | 10:57 PM
Alexan89's Avatar
Car: 89 CAmaro
Engine: 305 TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.45
Did u hit Brakes at all? i had it happen to me before. i had bad tie rod ends, and center link, so if i speed up really fast, and then barely tap my brakes, whole front end would just shake violently , until i slow down!
if it only happened to you once, then i wouldnt worry about! Its is definitely not an alignment issue! bad alignment would just cause ur tires to wear faster, not shake.
Old Apr 28, 2008 | 11:48 PM
doesnt do it when i hit the brakes, only if i hit a bump a certain way, like if i just clip it. its done it twice on two different occasions. im just wondering its bump steer cuz of the bias ply on the front?? im thinkin just put a bump steer kit on it and having it aligned??
Old Apr 28, 2008 | 11:51 PM
Alexan89's Avatar
Car: 89 CAmaro
Engine: 305 TBI
Axle/Gears: 3.45
That would be a good place to start!
Old Apr 29, 2008 | 12:00 AM
any body have any good specs for a drag race alignment?
Old Sep 12, 2009 | 09:16 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'm bumping this one back to the top, i had some terrible bump steer last night at the track. the car would leave with the fronts about a foot off the ground, and when it set them back down it would try to shake the steering wheel out of my hand. one time it was bad enough that i actually lifted. i just had the front end aligned and i'm wondering if having too much camber/caster is effecting it...i was thinking maybe that you could just shove the strut mounts back in toward the motor and the problem would go away.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
86White_T/A305
Aug 17, 2015 12:16 AM
