Rotating Wheels/tires
I have a 91 Z28 Convertible with 16" aluminum wheels of the new style for that year. I want to rotate front tires to rear. I was told that they may have different off sets. Looking at them, the rims all seem to have the same off set. Can anyone confirm whether the 91, 92 new style rims are the same off set on front and back?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rotating Wheels/tires
im quite sure the 16" wheels do, there should be a spacer on the front, and the wheels are marked front and rear.
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
There are no spacers. The wheels do have "front" / "rear" stamped on them. Will have to dismount tires to rotate.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Car: 86 Trans Am
On the rears, usually with iron drums (though my 85 IROC had them with disc brakes).
JamesC
JamesC
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My 91 RS rear drums had little spacers in the rear, like 1/8" or maybe 7/32".
Unfortunately you will have to dismount the tires from the rims to rotate them.
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
i had thin spacers on the rear of my 91 formula i took them off cause i didnt see the point in them
Car: IROC and 65 Mustang
Engine: IROC V-8
Axle/Gears: posi traction
I have a 91 RS with 305 and the 16" rims and drums out back. My rears to have spacers but the fronts do not (I do not believe any third gens had spacers on the fronts if you stayed with the stock 16"ers) my 88 IROC Z Convertible also has the stock 16" rims and the rears also have the spacers and I know in both circumstances you must dismount the tires to rotate them.
Fivestar
Fivestar
Andrew Prakash
Sep 8, 2015 11:48 AM
