335 or larger.
Old Dec 29, 2009 | 12:11 PM
Tricked-Out-Toy's Avatar
Car: 91 Z28
Engine: Lt1
Axle/Gears: 3.70 auburn pro 9"
335 or larger.
Who has them and post your pictures. Im going with a min 335 and would like to see how they fit.
Old Dec 29, 2009 | 12:19 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: 335 or larger.
I have plenty of pics on my CD site of 335s on my car with 2" spacers mounted on 11" wide ZR1 wheels. They bulged pretty good so I went with 315s and 1.5" spacers. Now they sit perfectly in line with the front wheels and there is less rubbing. Next time I get the car painted I will have the inner fender lips cut off, or rolled heavily. With will eliminate the rubbing alltoeather.
I have way to many pics on my CD site to post here. Check it out. I show what metal needed to be cut out to make them fit. I can also fill you in on how to make super cheap bump stops once you cut the stock ones off.
Old Dec 29, 2009 | 12:29 PM
Car: 91 Z28
Engine: Lt1
Re: 335 or larger.
wow they really stuck out there... Im Mini tubbing mine and probably relocating the LCA's to make room for a possible 355 but I really want to keep the look I have now with the ZR1's on the 4thgen rear.
Old Dec 29, 2009 | 02:39 PM
superirocz's Avatar
Re: 335 or larger.
I have hoosier 335s on my 17x11 zr-1 rims. The picture has the stock 9 bolt with 1/4 spacers and offset control arms with a mini tub.
https://www.thirdgen.org/forums/auto...t-rear-18.html
post 860 is me
The mini tub is not that hard to do and the wheels actually fit inside the outer fenders. I have since put a fab 9" in there so no need for 1/4inch spacers
Old Dec 29, 2009 | 07:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 335 or larger.
335/30/18, tucked under the fender, about 1/2" in from the face of the quarterpanel lip, just about where the tire is stock. Minitub, offset control arms, coilovers. the interior panels wont fit, had to widen them. That was more work than the minitub, over a year and im still nto done.
old pics, sorry, havent had time this year to get many new ones. Dont worry, the exhaust is fixed, i tripped on the pipe in the pic and it moved, crappy band straps.
Old Dec 29, 2009 | 09:32 PM
superirocz's Avatar
Re: 335 or larger.
what width are your rims and brand 86ta?
Old Dec 30, 2009 | 08:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 335 or larger.
they are 18x12, centerlines, they were widened 4", originally 18x8. 13.5" section width, 8.5" of backspacing on a 3rd gen width rear
Old Feb 26, 2010 | 02:23 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 335 or larger.
If you just have to get the most, Pirelli does make a 355/25R19, and it calls for a 12.5" wide wheel as the minimum.
Old Feb 26, 2010 | 02:34 PM
Car: 91 Z28
Engine: Lt1
Re: 335 or larger.
Actually, I plan on going with a 345/35/18 MT drag radial for most of my street use 12.8" tread width and a sidewall width of 13.89" hahaha GET SOME! there going to be MONSTERS back there!
Old Mar 1, 2010 | 11:29 AM
Engine: LS3
Re: 335 or larger.
Random side question.
Is it true that Nittos run a bit thinner in general when compared to other tires?
Also I assume you guys are going to be cutting most of your stock wheel wells out correct? Maybe going with relocated coilovers?
I will def be doing this someday. I run 315s now.
Old Mar 1, 2010 | 12:13 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Re: 335 or larger.
Is it possible to do this Mini Tub without the use of coil overs? I don't mind everything else but the coil overs have me on the fence.
Old Mar 1, 2010 | 04:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 335 or larger.
with mine, the standard 5" spring is in the way, i actually cut the hump up inside the spring perch almost perfectly in half during the minitub.
If you get a little creative, you could probably relocate the spring perches inboard and use a smaller diameter spring. Have to fab a new upper mount though.
And if things work out well, i may actually have pics of something like that soon along with another project ive been secretly working on
Old Mar 1, 2010 | 04:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: 335 or larger.
i can fit that no problem
86z89iroc
Oct 5, 2015 01:04 PM
lankchevy_350
Feb 17, 2003 08:48 PM
nixhex311
Feb 11, 2003 09:45 AM
chevymad
Carburetors
Feb 4, 2002 07:44 PM
CloudIROCZ28
May 25, 2001 09:03 AM
