drag wheel pictures combos
Old Jan 26, 2010 | 10:14 PM
zz4IROC's Avatar
Car: 1988 iroc
Engine: 350 forged crank, pistons, 11.5:1
Transmission: t-5
Axle/Gears: 10 bolt 3.73
I'm looking for some pictures of drag wheels. Anything that is staggered pretty much. I'm looking for something 15 inch, 8 or 10 inch wide in the back and 4 inch wide in the front. Anybody with summits pulsar wheels? Please put tire and wheel sizes too!!! thanks guys
Old Jan 27, 2010 | 08:04 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: drag wheel pictures combos
Try the button
Old Mar 3, 2010 | 07:20 PM
90rsmiami's Avatar
Car: 1990 RS convertible V8 auto
Engine: 305 Tbi
Transmission: auto
check out this link for Bogart Wheels. I think if your going with the whole street racer look these are the wheels to slap on there. http://images.google.com/imgres?imgu...26tbs%3Disch:1 actually this chart explains sizes and B.S wheels are your choice...i like the "Savoy" model
Old Mar 4, 2010 | 01:30 PM
jm84z28's Avatar
Car: 1984 Z28 camaro
Engine: 388 ci stroker
Axle/Gears: 3:73
i got summit pro stars rear 15x10 and front 15x4
Old Mar 4, 2010 | 01:34 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I just bought the same ones. With the 15x10's did you get the 6.5 babckspacing ? if so how long of a wheel stud are you using ? I guessing close to 3".
Old Mar 7, 2010 | 04:31 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
ill get pictures of my bird with the welds on it as soon as i get a chance. weather is just starting to get nice.
Old Mar 7, 2010 | 07:16 PM
budget350's Avatar
Car: 87 iroc, 91 rs
Engine: 350 worked, 305
Transmission: 5 speed zbar setup. auto
Axle/Gears: 3:73 gears. stock
15x4 up front with 165 kuhmo tires and 15x8 with 275s mt et streets out back.
Old Mar 10, 2010 | 08:00 AM
jm84z28's Avatar
Axle/Gears: 3:73
sorry for slow rply been busy but yea i search the fourm b4 i ordered and said to get arp 3in with shank style lug nuts so i bought those and works great
Old Mar 22, 2010 | 08:55 PM
ziggy89's Avatar
Engine: 383
i got the draglites on tonight ill try to get a pic up asap
Old Mar 22, 2010 | 11:13 PM
ziggy89's Avatar
Engine: 383
0322001947a.jpg?t=1269317578
i hope you guys can see it. never really posted pics b4
Old Mar 24, 2010 | 04:01 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I don't get it...that chart says the biggest 15" rim I can fit is a 8" wide with a 4" backset and use a 265/15 tire.
But with a 16" rim, I can get an even wider rim - 9.5" with a 5.5" backset??
-Why wouldn't a 15" rim work then with a 5.0 or 5.5" backset and a wider rim and tire??
Old Mar 24, 2010 | 05:52 PM
ziggy89's Avatar
Engine: 383
mine are 275/60/15 on a 15x8 wheel with 4.5bs. ive been told 5.5 is the most back spacing you can go with a 15inch wheel without mods
Old Mar 24, 2010 | 08:17 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
billet specialties street lites, 15x10, 6.5" backspacing. 15x4 fronts with a 165 kuhmo. i'm running a 275/60/15 mt et street radial:
the car is actually a bit lower in the front than in these pics as that was with the 5.7ls1 (aluminum) vs the 6.0l (iron) that's in the car now. i also am now running a 5/16" spacer between the hub and the wheel on the back, and it fills the fender abit better now. i'll get the car cleaned back up and get some more pictures.
Old Mar 25, 2010 | 08:17 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I thought it was a no no to run spacers drag racing.
Old Mar 25, 2010 | 08:18 AM
mw66nova's Avatar
Engine: 7.0L
can't imagine why it'd be a problem. i could see an adapator as being a problem, but a spacer that slides over 3" long arp studs...no issues yet.
Old Mar 25, 2010 | 08:24 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
It could be just me. I thought I read that they werent suppose to be used.
Old Mar 25, 2010 | 10:02 AM
huffediroc's Avatar
Car: 87 iroc
Engine: 350 with weiand 144
Transmission: tremec TKO 600,mcleod street twin
Axle/Gears: strange s60
15x10 with 275 60 15 and 15x4 fronts
Old Mar 25, 2010 | 11:08 AM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
15+8 Prostars. 15+3 fronts.
Old Mar 25, 2010 | 12:27 PM
ziggy89's Avatar
Engine: 383
it is a no no. ive seen it in the rule books but its been a while. then again thelet me get away with the stock spacer in the rear. all depends on the tech inspector and the track manager.
Old Mar 27, 2010 | 04:33 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Just put mine on today. 15x4 1.75 bs with Mickey 26x7.50 in front and 15x10 6.5 bs with Mickey 275/60/15 in back. Now I just need to fix my fender gaps with some lowering springs and i'm good to go.
Attached Thumbnails drag wheel pictures combos-100_7103.jpg   drag wheel pictures combos-100_7105.jpg   drag wheel pictures combos-100_7111.jpg
Old Mar 28, 2010 | 03:42 PM
Confuzed1's Avatar
Car: 83Z28 HO
They look great, but it doesn't help much if you don't tell everyone what the backspacing is on those wheels. I guarantee it's not a stock 4" backset on the rears...
EDIT: And for the guys running 6.5" backspacing, did you need to do any mods, or are the wheels "offset"?? Forget it...just saw 84Z's post....
Old Mar 28, 2010 | 08:52 PM
huffediroc's Avatar
Car: 87 iroc
sorry, thats 6.5" of backspacing, had to cut the first layer of metal and the bump stops. the material removed was on top of the upper inner fender with a grinder. didnt take long and its not as much work as people make it out to be
Old Mar 28, 2010 | 10:49 PM
mw66nova's Avatar
Engine: 7.0L
my bump stops are gone, and i have lots of inner fender "massaging". i also am running offset lca's. i'm going to cut a bit around the lca mount as well sometime when i decide to go to a bigger tire (want to run the new mt 295/55/15)
Old Mar 29, 2010 | 11:18 AM
huffediroc's Avatar
Car: 87 iroc
Hey how far offset are your lca's. Does somebody sell them or do you just move them yourself? It looks like I could take that lip on them, heat them up and pound it in to gain another quarter inch from the rim. idk, thats nice they offer that tire now(295 55 15) i think the next one up used to be a 295 65 15 which might have been too much sidewall for me
Old Mar 29, 2010 | 08:40 PM
mw66nova's Avatar
Engine: 7.0L
yeah, spohn sells offset lca's. they're rod ends with offset bushings.
Old Apr 7, 2010 | 02:44 PM
Thirdgen6.6l's Avatar
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
Dude that the kind I want, can you tell me everything about these wheel and tire, and where to get em ? btw how much these set up cost ? thanks
Old Jun 28, 2011 | 04:28 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
mw66nova: 3rd gen width rear axle?
Old Jun 28, 2011 | 04:44 AM
mw66nova's Avatar
Engine: 7.0L
yup, stock thirdgen width axle
Old Jun 28, 2011 | 05:10 AM
SLP IROC-Z's Avatar
Car: 1999 Z28
hmmm, im going to have to mock up my 4th gen width 9" to make sure a 15x10 7.5bs is going to fit under there. i like where yours is at
Old Jun 28, 2011 | 06:29 AM
mw66nova's Avatar
Engine: 7.0L
the 7.5" backspacing on a fourthgen rearend sits about in between where a 6.5 and a 5.5 sit on a thirdgen rear. it'd be like a 6" backspacing on a thirdgen rear i believe. it looks good if i remember correctly. try it!
Old Jul 4, 2011 | 11:54 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Subscribed
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
TMZIrocZ350
Exterior Parts for Sale
Aug 8, 2015 05:55 PM
