Summit fast five wheels, wheel stud length ?
Old Mar 2, 2010 | 10:19 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Just bought new rims and tires. I bought summit fast five wheels. 15x4 with 1.750 backspacing up front and 15x10 with 6.5 backspacing in back. I just test fitted the rim for the hell of it and the 12mm studs I have on now are way to short. My rearend is getting rebuilt shortly and my new axles are dual drilled for 7/16 press in and 1/2 in screw in studs. I was going to get the press in studs but I have changed my mind and want the 1/2 screw in studs. Question is how long should I get them ? I was planning on useing open ended 60 degree conical lug nuts which is what i believe i need to use on that rim just didnt want the stud sticking out a mile past the lug nut.
Old Mar 3, 2010 | 06:32 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: Summit fast five wheels, wheel stud length ?
bump
Old Mar 16, 2010 | 04:33 PM
Vortec_Formy's Avatar
Car: 89 Formula/94 z28
Engine: Vortec 350/ LT1
Transmission: WC T-5/ 4l60e
Axle/Gears: torsion posi 3.23s/auburn posi323s
I was curious about that too because i want to order the same wheels. A friend of mine has 15x10s but with 5.5in backspacing and regular lug nuts worked fine, so one more inch of bs is too much for stock lugs?
Old Mar 17, 2010 | 10:24 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I ordered these today. They should work. From what I understand you dont have alot of thread engagement with the acorn style lug nuts. So I'm going with 2" studs with open ended lug nuts.
http://www.summitracing.com/parts/MSR-8002/
http://www.summitracing.com/parts/GOR-90087/
Old Mar 17, 2010 | 12:59 PM
oh alright, i'll do that as well. was curious since my friends can use regular acorn style lug nuts with his 5.5in bs.
Old Mar 17, 2010 | 01:09 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
You can use regular acron style lug nuts,I'm just going with open ended ones cause i'm getting longer wheel studs. And make sure your axle is drill for the 1/2 20 wheel studs before you go buying what i bought. I have aftermarket axles that are drilled for them. All thirdgens came with 12mm x 1.5 press in studs so you will probably want those.
Old Mar 17, 2010 | 05:05 PM
ha....duh, I forgot its 12x 1.5. with a factory rear end do you think i will have to buy longer studs then?
Old Mar 17, 2010 | 05:09 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I mocked up my rims and they dont look like they will have enough threads to grab. You will probably need longer ones.
Old Mar 17, 2010 | 05:17 PM
oh alright, not a problem. do you think the rim will and tire will clear fine? I have the front lip rolled. the car does sit around 2 in lower in the rear.
Old Mar 17, 2010 | 06:13 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Your gonna have to at the least cut out the bump stop and maybe work the front of the wheel well.
Old Mar 17, 2010 | 06:27 PM
hmm ok, i'll prob also raise the car about an inch in the rear as well.
colton_carlson
Mar 8, 2019 12:21 PM
redmaroz
Apr 25, 2017 07:14 AM
Scamo-2.8
May 20, 2016 07:01 PM
kah992
Aug 19, 2015 02:55 PM
