Wheel Adapters
Old Jun 8, 2010 | 07:21 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Wheel Adapters
I just bought some corvette spyders 18x9.5 for the front and 19x11 for the back. I was wondering what size wheel adapters I would need.
Any help is appreciated.
Old Jun 8, 2010 | 07:29 PM
Stephen's Avatar
Car: 87 GTA
Re: Wheel Adapters
Please use the feature. That has been answered a billion times & there are a billion threads about it.
There is even a sticky on the top of this Forum.
We don't need a billion & one threads on the same old subject.
Old Jun 8, 2010 | 09:15 PM
396l35's Avatar
Car: 3 1969's and original owner 1987
Re: Wheel Adapters
Im running 17x11 and 17x9.5 vette wheels and as long as you have a total with spacers less than 5.8" backspace for the rear and 4.6" backspace in the front you'll be fine. On mine 17x11 the wheels had a backspace of 7.8 and I put a 2" spacer which brought it down to 5.8" total backspace with no rubbing. The front wheels I went with a 2.5" spacer because the backspacing was 7.1" and I have about a 3/8" clearance to the tie rod and no rubbing. I hope this helps. Mark
Old Jun 10, 2010 | 10:38 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
Re: Wheel Adapters
I am running 17's and I use a 1.5 inch spacer in the back, I had 2 inch spacers but I did not like how far the wheels stuck out..
Old Jun 10, 2010 | 11:39 PM
396l35's Avatar
Re: Wheel Adapters
1.5" spacers will work but it all comes down to your wheels backspacing to start. I figured out the magic number has to be 5.8" backspacing with the wheel and spacer together. This gives you enough clearance to where you dont have to cut the bumper or inner wheel well out. Here are some photos of mine with the 17x11's on the rear.
Old Jan 23, 2011 | 08:56 AM
jtlockwood88's Avatar
Car: 88 Formula 350 / 87 Iroc 68k miles
Engine: 355 / 355
Transmission: 700r4 / 700r4
Axle/Gears: 10bolt w/3.23 - 9bolt w/3.27
Re: Wheel Adapters
DUDE i love that look! im guessing you got that those at oewheel, if not where did u get them? also i wass wondering if there was anything else done to the rear end, such as axle swap?
Old Jan 23, 2011 | 10:08 AM
Stephen's Avatar
Car: 87 GTA
Re: Wheel Adapters
[QUOTE=396l35;4575193]1.5" spacers will work but it all comes down to your wheels backspacing to start. I figured out the magic number has to be 5.8" backspacing with the wheel and spacer together. This gives you enough clearance to where you dont have to cut the bumper or inner wheel well out. Here are some photos of mine with the 17x11's on the rear.
Looks like your rear end if off by a bit to the drivers side & could benefit from using an Adjustable Panhard Bar, to re-center it.
Old Jan 23, 2011 | 10:11 AM
396l35's Avatar
Re: Wheel Adapters
No actually these are used 1996 Gran Sport Coupe wheels. The coupes had wider wheels in the rear then the convertibles. Im glad you like it, I even bought a set of GTO spares that have the wording ground off and re-powder coated with the polished lip like the other wheels. They are a close match to the Gran Sport wheels and great for the track... Mark
Old Jan 23, 2011 | 10:14 AM
396l35's Avatar
Re: Wheel Adapters
It is a little off but when you see the car in person it all blends together and you dont notice the little imperfections.
Old Jan 23, 2011 | 10:20 AM
Stephen's Avatar
Car: 87 GTA
Re: Wheel Adapters
I didn't on my either (17x11/315s), until I hit a bigger dip in the road than I thought it was, & my drivers sides tire met the inner fender lip, Cut off a nice little slice of rubber!
Looks wasn't what I worried about.
Old Nov 24, 2013 | 09:23 AM
trans_am84_'s Avatar
Car: 1984 trans am
Engine: 350 ci
Transmission: 700r4 soon to be 350t
Re: Wheel Adapters
Does anybody ever have problems with studs breaking off with using spacers on Yvette wheels? That's my only concern cause I'm in mn
Old Nov 25, 2013 | 10:37 PM
ReEntry Racer's Avatar
Car: '82 TA GT1 Roadracer
Engine: ZZ4 Fast Burn 385
Transmission: TEX101A Dog Box
Axle/Gears: 3.73 4th Gen w/Auburn Racers Diff
Re: Wheel Adapters
Yes. Change them to ARP 12mm and you'll be good.
Old Nov 26, 2013 | 04:08 PM
Car: 1984 trans am
Engine: 350 ci
Re: Wheel Adapters
Thanks for the input! Its appreciated
Twin_Turbo
Mar 14, 2016 10:10 PM
JB82Z-28
Exterior Parts Wanted
Oct 6, 2015 09:05 AM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
