Front IROC wheel for spare
Old Jul 7, 2010 | 10:39 AM
shuanm's Avatar
Car: 84 Z28
Engine: Stealth Ram 355
Transmission: Borg/Warner T5 WC
I have a 84 Z28 with IROC replica wheels. I have a set of spare IROC wheels from a 86 IROC that I destroyed. Will the front IROC wheel work on both the front and back of my 84 so I can use it as a spare??
Old Jul 7, 2010 | 05:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Front IROC wheel for spare
yes, fronts will work on the back, the rears will not work on the front
Old Jul 7, 2010 | 06:02 PM
shuanm's Avatar
Car: 84 Z28
I noticed that the front stocker looked like it had the same configuration as the replicas, but wasn't sure about the specs. Thanks TA.
Old Jul 8, 2010 | 11:47 AM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
It won't work. You might as well sell me the iroc wheels...
Old Jul 9, 2010 | 06:36 AM
shuanm's Avatar
Car: 84 Z28
Make me an offer. I need new tires anyway.
Old Jul 9, 2010 | 09:28 PM
shuanm's Avatar
Car: 84 Z28
Micktroup2?? Want some wheels??
Old Jul 10, 2010 | 09:59 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
FYI it WILL work, micktroup2 is full of ****.
but if he wants the set, you can always find another spare.
Old Jul 10, 2010 | 12:06 PM
shuanm's Avatar
Car: 84 Z28
I'm sure it will work. I got the joke. I have other Camaro wheels to use as a spare.
Old Jul 10, 2010 | 01:00 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Does a 16" iroc rim (front) fit in the trunk well of the car? I wanna relocate the battery to the rear spare compartment but if i go on a long trip i'd like to have a spare just in case.. I was thinking that ONE universal IROC wheel would do the trick.. If not, I guess it'll have to go in the back seat lol
Old Jul 10, 2010 | 08:44 PM
shuanm's Avatar
Car: 84 Z28
I don't think it will go in there, but it will fit in my wifes trunk. I don't have a spot for a floor jack either, but I'm not takin that clunky jack for a ride when I can have those tools delivered. From what I gather a front IROC wheel will get you home on either end of the car, but it won't fit in the quarter panel I'm sure.
Old Jul 10, 2010 | 10:16 PM
not the quarter panel, i meant the area in the back after the gas tank (there is a deep space there..).. I guess i'll go measure tomorrow actually nvm that question!
Old Jul 11, 2010 | 12:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it should fit there, but defiantly not in the original spot in the quarter
Old Jul 11, 2010 | 12:16 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Note the instructions/pictures in your owner's manual. The semi-circular cut in the carpet on the down slope of the well hides a place for the tire stowage bolt. The tire must be fully seated into the depression to provide clearance to window (full size flat).
JamesC
Old Jul 12, 2010 | 02:34 PM
matchbox's Avatar
Car: 87RS/70 novaSS/85 Z28
Engine: 2.8L/468 HP unknown/HO305
Transmission: 700r4,T400,stock
Axle/Gears: stock,fab9,stock
The front iroc wheels are a 4 3/8" back space and rears are 4 7/8" back space. I use a rear on the front but put longer studs and 1/2" spacer. Using fronts on the rear you might check clearence at wheel well.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
