Max wheel size on a stock wheel well
Old Oct 12, 2010 | 11:04 AM
Want a 3rd gen's Avatar
Car: 88 Iroc
Engine: LM7
Transmission: TH 400
Axle/Gears: 12 bolt 3.91
I am looking to purchase a set of Weld RT-S wheels for my 3rd gen. I want to go with the 15x9.25 sized wheel, but which offset?
Weld offers that size in a 5.5 BS and 6.5 BS.
I DO NOT want the wheel/tire to stick out at all. I would like for it to tuck under as much as possible.
Pics for s-n-g's
Old Oct 12, 2010 | 03:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Max wheel size on a stock wheel well
of the two sizes, 6.5 would be best, but will require modification to the inner wheel well to fit. depends a lot on what tire you are using too. 6" of BS should work too, but i dont think its an available sepc on those wheels
5.5 may just work if the wheel is only 9" wide, but the tire bulge may still be out a bit further than you would seem to like.
Old Oct 12, 2010 | 04:03 PM
Car: 88 Iroc
Engine: LM7
thanks for the input!
Anyone out there happen to have either of these wheels on their car? Even if it's not an RT-S, just to see what I prefer
Old Oct 12, 2010 | 04:50 PM
Stephen's Avatar
Car: 87 GTA
My 9" wide, 5"bs Snypers with 275s tucked very well. Too well for my tastes. The 5.5" bs would be your best choice & yeah....6.25 would require some BFH mods at minimum, but most likely cutting to clear the tire sidewall at least.
Old Oct 12, 2010 | 05:45 PM
Car: 88 Iroc
Engine: LM7
Stephen, sent you a PM
Old Dec 17, 2012 | 03:57 PM
383strokerbird's Avatar
How tall and wide can you go with the stock wheel wells??
Old Dec 18, 2012 | 11:51 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
6in back space is perfect. 6.5in requires a .5 or 1/2in spacer. 5.5 put it at the edge of the outer fender. I'm running a 18x9.5 rim with a 6in backspacing.
Old Dec 19, 2012 | 10:31 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Keep this in mind - if you want to run the 9.25" wide 15" wheel in front, you can't run more than 5.1" BS and not hit the tie rod end without a spacer. Rea is a different story, but no one has mentioned the fronts so far in this thread...
Old Dec 19, 2012 | 01:33 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
I love all these zombie threads that keep crawling out of the grave!
Old Dec 19, 2012 | 01:34 PM
Car: 1971 Camaro
Engine: 427
The guy got his wheels a long time ago and is selling the car now,.
https://www.thirdgen.org/forums/cama...c-ls-swap.html
BlueIroc-Z
Jun 9, 2019 03:22 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
Linson
Aug 21, 2015 02:12 PM
knight72
Aug 10, 2015 09:32 PM
