Fix-A-Flat canister instead of Spare, good idea?
Old Oct 24, 2010 | 06:23 PM
OddJack's Avatar
To save weight? Is it good idea to get one of those fixaflat cans and get rid of the spare tire and the jack? I have not had a flat tire in the past 6 years, have you ever had any experience with them?
Old Oct 24, 2010 | 06:46 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Fix-A-Flat canister instead of Spare, good idea?
no, if you want to add one in addition, maybe, but taking the spare out of a driver isa bad idea. Probably have a flat within a week of doing it.
if the blowout is bad enough, fix-a-flat wont do anything.
Old Oct 25, 2010 | 12:30 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Like your insurance or airbag, parachute, gun or nuclear weapons. You hope you never have to use them but if they're not there when you need them, you're boned.
Old Oct 25, 2010 | 06:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
My spare is in place, an inflatable (I'd be afraid to use it at this stage), so I carry a can of Fix-a-Flat.
JamesC
Old Oct 25, 2010 | 07:15 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Not a big fan of FIX a FlAT in a can...Lot of tire shops will not touch a tire with that repair.
Old Oct 25, 2010 | 07:33 AM
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
They will but you have to tell them it has fix a flat in it.
If the tech tried to just plug a fix a flat tire he could have his arm blown off.
Old Oct 25, 2010 | 07:41 AM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
I don't have a spare in my car, but I don't drive the car very far away. I do have a plug kit in the car. You can buy one at the auto part store, it will give you the tools and the plugs to do the repair yourself. Like the people above have said it (will not) help if you have a blow out.
Old Oct 25, 2010 | 09:31 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
His arm blown off?
Old Oct 25, 2010 | 10:06 AM
Fix a flat is a chemical that releases gas to fill the tire.
To plug a tire yo have to reem out the hole with a file thingy. If there is fix a flat in the tire and you do this you can cause a spark and when the spark lights the gas in the tire the tire becomes a grenade.
Learned about this in tech and from what I have herd from working 5 years as a line tech it has happened before.
Old Oct 25, 2010 | 10:12 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Fix-A-Flat is good for small holes that you normaly can't plug without hammering the reamer in to be able to plug it . The only thing with Fix-A-Flat is alot of people don't use it properly as everyone knows you use it to air the tire up and you drive it to slosh it around in the tire then add air to proper psi but you also have to keep airing the tire down then putting air back in to get rid of the excess fluid in the tire and the gases that are in the Fix-A-Flat which are explosive and flammable .
Old Oct 25, 2010 | 10:14 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They haven't used explosive ingredients for years. Fix-a-flat itself has been non-flammable since 1999. Even still, deflate the tire to plug it, or demount it to patch it first and it's not a hazard.
Old Oct 25, 2010 | 10:18 AM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
I have not used it in years so it would make sence that they changed it like other stuff has changed for stopping "Global Warming" .
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Fast355
Dec 2, 2016 06:33 PM
mdtoren
Aug 16, 2015 05:45 PM
