Tires for GTA wheels
Car: 1986 Firebird Project
Engine: 3.1L
Transmission: t5
I figure this is on here a million times, but I can't find it.
I have bought stock 16x8 GTA wheels and am now looking for tires. I really want to know what the stock sizes were and what the largest tires I can run front and back.
I would like to run the same sizes on all 4 corners. Any input or tire suggestions would be greatly appreciated.
Car: 87 GTA
Re: Tires for GTA wheels
245/50R16 is the stock size. For 16" wheels, 255s are basically the biggest you'll get in a street tire except for the BFG 295s, which won't fit up front.
So 255s is what your limited to.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
255 will give you a tall looking tire and looks kind of goofy go with 245's.
Car: 87 GTA
First off, 255 is only 10 millimeters WIDER (not taller)
And secondly, the aspect ratio (45 or 50) is only a percentage number of the width. So the overall diameter of a 255 vs a 245, for the same aspect ratio, would only increase by 5 millimeters. You'll never notice 5 millimeters in height.
Car: 89 GTA
Not at all..
Car: 87 GTA
I've run 255s on all 4 corners & even the BFG 295/50s on the rear. Loved them all!
Engine: 3.1L
Transmission: t5
I appreciate the input! I think I'm going to go with the stock 245s on all 4 just because I like the look and it will be a while before my car gets the mods to really need tires this big. As far as that goes any suggestions on tires or brands? Or ones to avoid? Thanks
Car: 91 GTA
Axle/Gears: 3:73
i really like the look of the nitto 555! the drag radial looks sick and was wondering if i can get a street tire with the exact same tread pattern. i might consider the drag radials but im running a 10bolt rear. im on the fence because its still a mild motor and a weak rear end, but my 3:73 are sweeeeet. Is 555rt avalible in the 245/50/16? or any quality tire with a thick looking design, (looks matter)!
Its no longer a popular size, i wish i had 17'' rims
Car: OVRMYHD
Engine: H/C/I LS1
Transmission: 4L60E 3,200 Edge stall
Axle/Gears: 9 bolt w/3.90
Michelin Pilot Sport A/S are about the best tire you can put on there. I found them for 158 a tire @tiredirect.com. Free shipping.
1992rs/ss
16
Jan 28, 2016 09:58 PM
