Advice on tire size 18 inch
Old May 26, 2011 | 11:23 PM
ricci66's Avatar
About to order some 18 inch iroc wheels , a friend suggested to go with 245/45/18 front and 275/45/18 rear ,......... Anyone out there have this setup ? pretty sure they would fit without rubbing .............any other suggestions are welcomed ,the car is all stock height right now .Thanks
Old May 27, 2011 | 04:18 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Advice on tire size 18 inch
Too tall and way too tall. Stock is 25.7". 245/45-18 is 26.8", 275/45-18 is 27.9. Also, a 275 is too wide for an 8" width. 255/40 would be ideal, IMO.
This is what 245/40-18 and 285/35-18 looks like:
Attached Thumbnails Advice on tire size 18 inch-dscf1603-small-.jpg   Advice on tire size 18 inch-dscf1597-small-.jpg
Old May 27, 2011 | 06:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
those iroc wheels are only 8" wide though right? you cant use much more than a 245/40 on them.
Old May 28, 2011 | 09:59 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Ricci - I am planning on using pretty much the same tire size as you listed. I know they are taller and I'm ok with it. My concern is my long tube headers and 3" exhaust bottoming out once I lower the car. My thought is that the tire helps fill the wheel well and also raises the car slightly for ground clearance.
Just so you know, your speedo will be off with a taller or shorter tire than stock.
Old May 28, 2011 | 10:10 AM
ricci66's Avatar
...The Rims are listed as 18 x 8.5 ....the company im looking at is installing the tire size i request , Thanks for the input.......... im waiting for the forum thoughts before placing the order .
Old May 28, 2011 | 05:29 PM
mario 91-87's Avatar
Car: 91 and 87 camaro
Engine: 91 360ci and 87 350ci
Transmission: lt1 t56 ,wc t5
Axle/Gears: 3.23 2.42
im running the 18 x 8 irocs with 255/40/18 front and 275/40/18 rear and my car is currently drop 3in on the front and 2.5 rear no issues
Old May 28, 2011 | 05:37 PM
Advice on tire size 18 inch-stock-height.jpg stock heigth
Old May 28, 2011 | 05:48 PM
[ATTACH]219997[/ATTACH
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
knight72
Aug 10, 2015 09:32 PM
