Will an 11" wide wheel fit with 2.25" adapters?
Car: 91 RS, 84 Z28, 85 Iroc-z
Engine: 3.1L, 350 4 bolt, 350 TPI
Transmission: 700R4, 700R4, 700R4
Axle/Gears: 3.23, Unknown, Unknown posi
Just what the title says, will an 11" wide wheel fit my 91 rs rear with 2.25" adapters?
I plan on using 295 30 r19 tires also
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
Re: Will an 11" wide wheel fit with 2.25" adapters?
too many variables to say yes or no, specs on wheel? most likely will need wheel well work, see my post on the same topic in the fabrication section
Don't really car if they stick out a little and my car isn't lowered so I can go bigger with the spacer
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Whats the backspacing/offset with these 19x11 wheels?
If its a C6 vette type wheel it may work...I got 19x10's with 295's and use 4th gen rear plus 5/8 spacer. total adder with that spacer and 4th gen rear is around ~2.4-2.5".
So most thirdgen rears would use 2.5" for 10" wide C6 wheel with that high offset/backspacing.
11" with different spacing would require different spacer length.
They have 9.09" bs and yes its a vette c6 19x11 wheel
Car: 82 Trans Am
Transmission: t-56
Will hit fender with 2.25" spacer
Alright... What are you using?
Looking at your thread you say you fabbed your rear an inch wider than stock and you had the 2in adapters. So wouldn't that mean I would need 2.5in adapters to have the same bs as you? I'm planning on getting the same wheels as you
ambainb
Apr 25, 2016 09:21 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kah992
Aug 19, 2015 02:55 PM
