Would 14" winter tires on my IROC be a problem?
Old Dec 30, 2011 | 09:19 AM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
Hello guys,
I found a set of 14" winter tires for my IROC off craigslist...They come with the rims already. I know they fit, because they came off the sellers berlinetta. However, with my IROC already being pretty low (lowered on Eibach Sportline rims), would there be a problem with getting 14" rims? (it's got stock 16" rims right now). I guess what I mean is....will it be THAT much lower??
Thank you!
Old Dec 30, 2011 | 10:01 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Would 14" winter tires on my IROC be a problem?
Compare the overall tire of the tires. That will tell you if they'll fit & how low/high (tall tires?) will be sitting after the swap.
Old Dec 30, 2011 | 10:13 AM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
a 215/70/14 will sit at the same height as a 215/65/15
strange huh?
Old Dec 30, 2011 | 10:14 AM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
really mark?
If that's true then I'll be ok thank you !!
edit: the size of the tire is 195/75/R14, but it's not that far off
Old Dec 30, 2011 | 10:15 AM
58mark's Avatar
yep, check out this chart
http://www.tirerack.com/tires/tires....=yes&tab=Specs
a 195 is a full inch different
Old Dec 30, 2011 | 10:16 AM
Car: GTA
Originally Posted by Skyset
really mark?
But you have 16" tires, so 58marks "help" is of no use to you.
Old Dec 30, 2011 | 10:17 AM
58mark's Avatar
if he has the CORRECT 16" tires, then the diameter of the tires+ wheels doesn't change
I was showing him that the size of the wheel doesn't have that much to do with the full diameter of the setup
Old Dec 30, 2011 | 10:19 AM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
blackened, I had 15" rims on my car for a while so I know that they fit good =)
Old Dec 30, 2011 | 10:20 AM
Car: GTA
Originally Posted by 58mark
.....size of the wheel doesn't have that much to do with the full diameter of the setup
Exactly what I had pointed out already.
Old Dec 30, 2011 | 10:21 AM
58mark's Avatar
glad I could help... despite some people saying I was of "no help"
Old Dec 30, 2011 | 11:01 AM
Car: GTA
Your first comparison of 14" tires to 15" tires didn't apply to him with the 16" tire size, so how could it have been of any help? You posted a link to compare tire sizes AFTER I said something. You shoulda posted that link in the first place. So no...Your first post was of no help to him.
Wheel diameter means squat in this case. Only the tire size does. When you need to know about brake rotor sizes that fit? Then the wheel size matters.
Old Dec 30, 2011 | 11:04 AM
58mark's Avatar
really mark?
the OP disagrees with you, and that's all that matters
customblackbird
Aug 15, 2021 10:16 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
Fronzizzle
Aug 17, 2015 02:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
