paint stock wheels
Old Jan 8, 2012 | 10:22 PM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
paint stock wheels
is it possible to paint stock firebird rims the formula ones and if so with what paint ant what prep and how to
Old Jan 8, 2012 | 10:30 PM
oneScoopsEnough's Avatar
Car: 1986 IROC-Z Ttop & Iroc Coupe
Axle/Gears: posi unit?
Re: paint stock wheels
yes you can any color you want. Use something to clean them with like some paint prep stuff for metal.Or you can get them powder coated,chromed or even black chrome
Old Jan 8, 2012 | 10:32 PM
Engine: sbc 350
sweet would regular wheel paint work
Old Jan 8, 2012 | 11:17 PM
i am sure if you are painting the metal part and are really cleaned before appyimg
Old Jan 8, 2012 | 11:26 PM
if you check around there also may be some kind of acid that you can clean them with.I used to service air conditioning units and you would clean them with a aluminium acid. That stuff worked great on my old 15" RS rally wheels.I would probably definitely use a kind of wheel paint instead of reg. paint probably hold up much better
Old Jan 9, 2012 | 01:17 AM
Engine: sbc 350
sweet could I sand them with a high grit paper Mabey
Old Jan 9, 2012 | 01:30 AM
i guess almost like painting a car you may even want to primer and coat but i never went that far but if you really want them to look nice i would definitly put some time into it especially getting them clean of all dust and make sure you wash them after you sand or whatnot
Old Jan 9, 2012 | 02:16 AM
Engine: sbc 350
ok thanks probably start tomorrow lol
Old Jan 9, 2012 | 08:35 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Aircraft stripper works wonders, available at most auto arts stores.
I used some self etching primer on mine, followed by a couple of coats of caliper paint on my 15" RS wheels. They held up pretty good before I sold them. They lived on an S10 for a while and, last I heard, did really well with little or no maintenance for the last couple of years.
https://www.thirdgen.org/forums/auto...old-stock.html
Vintageracer
Jan 10, 2020 05:33 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
Exxon Limited
Aug 9, 2015 08:13 PM
