wheel specs
Old Jan 15, 2012 | 09:23 PM
Project-RS's Avatar
wheel specs
hows it going. as of right now im trying to find a newer set of rims. i like my 17's, but i dont want to run the 2" adapters anymore. so heres my questions. 1. rear rims, whats the widest i can run with a 3rd gen rear end? 2. rear rims, how much of a lip (deep dish) can i get [ rim will sit flush with the fender ]?
i want a really agressive look, and i think having a deep dished rear wheel with a front wheel with less of a deep dished wheel will set it off right.
any help is much needed,
project-rs
Old Jan 17, 2012 | 06:10 PM
Project-RS's Avatar
Re: wheel specs
anyone?
Old Jan 17, 2012 | 06:21 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: wheel specs
thats not a simple question, there are millions of wheels and the design of the wheel will dictate the lip, its not usually an option to just ask for x amount of lip with my wheel please.
17x11 will fit the rear, 6.5 to 7" of bs work, more is better, but will reguire some metal work.
to avoid spacers you will need a 4th gen rear, or a custom 3pc wheel from a place like ccw, hre, bose, ect. it will get pricy
Old Jan 17, 2012 | 06:26 PM
Project-RS's Avatar
Re: wheel specs
thanks for that info. i was thinking if i keep the shorter rear, that i can have a rim with a wider lip. im not afraid to cut up my car. if you seen my threads you can see it.....lol i plan on doing a mini tub, but not to extreme.
Old Jan 17, 2012 | 06:31 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: wheel specs
The cheapest, and best way, would be to get a 98+ rear end. Better brakes, better "posi", less mileage/wear, etc.
Old Jan 17, 2012 | 06:37 PM
Project-RS's Avatar
Re: wheel specs
i want to do that swap, just thought i can get a wider lip rim using a shorter rear end. going from aluminum drum to disk will be a huge improvement
Old Jan 17, 2012 | 07:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: wheel specs
if you want a big lip, you need the narrower rear axle. If you are doing anything close to a "minitub", you better be using something more than a 11" wheel since like i said before, that will fit with minor work. unless you are using really tall drag slicks or radials, in which case the tub would be more for height
Old Jan 17, 2012 | 07:42 PM
Project-RS's Avatar
Re: wheel specs
right now im running 17x10.5 wheels with the 2" adapters. if i plan on keeping the narrow rear, i will either build a disk rear or buy a prefabbed 9".
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
mrdevontay
Sep 2, 2015 08:04 PM
