295/50 R 15 indy 500 on a OE rim :->
Car: 1987 camaro Z28
Transmission: manual
just wanted to show u guys it fits and it looks mean...and the rims are not 7 inch like most people think they are 7.5
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 295/50 R 15 indy 500 on a OE rim :->
If you're getting 7.5" then you're measuring it wrong. Stock 15s are 7.0" Plenty of us, myself included, have measured several sets of stock wheels.
Yes u r right... The balancer is a bit of... They are 7 it ses on the inside...
that looks mean as hell, i have 275/60R15s on my 454SS truck, and thats stock size, my wheels are 15x7 just like those z28 rims
now i wounder, how wide can i go on my IROC 16s? lol
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
The question isn't if it fits but if the center is going to wear faster than the outside as if it is overinflated. I personally really like the looks of the 295/50R15 and have a set of 8 inch wheels I am planning on running. Everything I read basically says 8.5 - 9.0 inch rim width minimum. I was assuming I might be better with 275/60's on them 8 inch wheels.
Well will see about how they ll go...I wanted 255 wide but as u guys know Indy 500 is discontinued ,so that is what was left ..I work at experttire ...we check all the stores ,no 255 ...I will go whit 235/60 r15 in the front a bit later...I think 8 inch weeks will be fine I even mounted one on an 8 inch sorry no pic ...there is something else if I put this tire together whit 245/50r17 they are almost the same shade of wide
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
they are 15x7 wheels, period
the advertised width of the wheel is similar to "trade" sizes for various other parts. its not a exact number. Its the distance between the bead seats of the wheel, not the overall width, the diameter is the same way. measure it, its not 15", closer to 16.
a 7" wheel will typically measure, overall width, around 8", in your case its a little less.
the factory 16x8 is 9" wide overall, the 10.5" wheels on my 92 are 11.5" overall, the 12" wheels on my 86 are 13" overall, ect ect.
those tires are not recommended for you wheels, but people do it.
The tire still sits pretty straight ,car drives well ...till I get wider rims , that's how is gonna roll
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
295 on a 7" wheel is unsafe - you need at least a 9.5" to do it with confidence.
Yup I m afraid to say it is unsafe ...rear end feels like a boat on the freeway...needs wider rims for sure...I just got the tires befour my boss sell them...they were only 4
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
