need some help.are these gta rims?
Old Jul 16, 2012 | 10:12 PM
platynumx's Avatar
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
There 16 in and are 8 in wide. Post says they were on an older pontiac grand prix and I don't know if pontiac had similiar rims for other models. Bolt pattern is 115mm. (I dont know lug patterns in metric )Tia
Old Jul 16, 2012 | 10:16 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Re: need some help.are these gta rims?
Those look like GTA's to me just in bad shape the outer wheel rim looks damaged
Old Jul 16, 2012 | 10:18 PM
Phenom-1's Avatar
Engine: 5.7 TPI
The only difference is the Emblem in the middle, GTAs had the Gold or Silver bird emblem on the center cap like this one
http://images.canadianlisted.com/nla...es_4816771.jpg
Old Jul 16, 2012 | 10:21 PM
Phenom-1's Avatar
Engine: 5.7 TPI
Front wheels had zero offset & rear wheels had 16mm offset
Old Jul 16, 2012 | 10:24 PM
platynumx's Avatar
Those rims look different compared to the pic I posted. The lace is pointed in my pic and cr.ossed on yours(the outside of the rim)
Old Jul 17, 2012 | 12:41 PM
Scott85's Avatar
Car: 91 B4C
Transmission: auto
Those aren't GTA rims.
Old Jul 17, 2012 | 12:48 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Third gen bolt pattern is 120.65mm.
Those definitely look like Grand Prix wheels which have a more positive offset and different bolt pattern.
Old Aug 2, 2012 | 02:55 PM
WestTA310's Avatar
Car: 1986 Firebird Trans Am
Engine: 305 TPI V8
Those Are Not Gta Wheels The Spokes And Lip Are Diffrent And Where The Lugs Go In Its Shaped Diffrent And They Say ABS On The Center Caps
Old Aug 2, 2012 | 04:10 PM
makingPAIN's Avatar
Car: 1985 firebird
Engine: 350 .40 over
Transmission: 5 speed borg(NWC), ram clutch
Axle/Gears: ROTATING MERCURY DRIVE.
whats with the inner star between the lug holes???? is that gta?
Old Aug 4, 2012 | 01:07 AM
WestTA310's Avatar
Engine: 305 TPI V8
The Center Pattern Is Diffrent Grab A Trans Am/GTA Center Cap And Try Fitting It But It Will Most Likley Not Fit, But You Can Also Tell By The Numbers And Codes In The Back Of The Wheel Do They Say "8JJX16 OFFSET 00 OR MADE IN JAPAN" But I Can Tell You Those Are NOT GTA WHEELS
Old Aug 4, 2012 | 09:51 AM
fbodyalltheway's Avatar
Car: 1992 firebird. 1984 Trans Am
Engine: 3.1L. L76 coming soon
Transmission: 700R4. T56 coming someday
They are grand prix rims.
GTA
GRAND PRIX
birdman_29
Jan 7, 2017 08:24 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
raymondandretti
Sep 5, 2015 05:02 PM
