The heck with spacers....Which Rushforths?
Old Aug 29, 2012 | 01:30 PM
Blowtorch79's Avatar
Car: 1989 Formula 350
Engine: 383ci, +150hp N20
Transmission: Built 700R4
Axle/Gears: Moser 9", 3.73 Detroit locker
I am saying the heck with going the spacer route and getting me a set of Rushforths and Baer Brakes. If you are going to do it, do it right! I need some help picking a wheel. I am going to have the centers painted black on either wheel but help me figure this out.
18x9 Fronts on 275/35/18 Nitto NT05's
18x10 Rear on 295/35/18 Nitto NT05's
Baer 4 Piston 13" front and rear
What do you guys think?
Going on my Black 1989 Formula 350 (Petunia)
Old Aug 29, 2012 | 01:57 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Re: The heck with spacers....Which Rushforths?
I only see 1 wheel.
Old Aug 29, 2012 | 02:01 PM
BADNBLK's Avatar
COTM Editor
Not sure if the Trooper is an option, but it is the Rushforth wheel I am in love with. Jason is such a solid dude and will give you his design opinions on what size color combo etc... to make your car look the best with his wheels... BALLER btw
Old Aug 29, 2012 | 02:03 PM
Not sure why this didn't post the first time.
I'm between the Night Train and Rated X
Old Aug 29, 2012 | 02:06 PM
BADNBLK's Avatar
COTM Editor
Post a pic of your car BTW... So we can envision the beauty of the combo!
Old Aug 29, 2012 | 02:08 PM
@ BADNBLK
He seems like an awesome guy. I'm actually getting my brakes from him as well. When I stated this project I was going to keep the original wheels and brakes....but the engine started as some bolt-ons and turned in to a stroker. Might as well go ***** to the wall with her.
My old Petunia is going to be better than ever.
Old Aug 29, 2012 | 02:16 PM
This is the only one I have on me...I took this the morning I dropped it off at the enigine builders. She hasn't seen rain since I was 19 (14 years) and wouldnt you know it....it rained that day.
Old Aug 29, 2012 | 02:58 PM
BADNBLK's Avatar
COTM Editor
Your pic didn't show...
mmmmmm... sexy! Rated X
Night Train!
Old Aug 29, 2012 | 06:28 PM
87350IROC's Avatar
Car: 87' IROC
What so what specs did you end up with on the wheels?
John
Old Aug 29, 2012 | 08:19 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
I like the nighttrain looks sinister
Yea your pic not showing ?
Old Aug 29, 2012 | 08:52 PM
BOTTLEDZ28's Avatar
Transmission: A4
The only issue I have with all these wheels is getting the correct backspacing and offset specs so that they end up looking like the ones in the pics on those cars. We all know the 3rd gens are a beotch to get nice custom wheels that have a deeper lip in the rear then the front without having the front wheel stuck so far inside the wheel well.
Old Aug 30, 2012 | 12:15 PM
BADNBLK's Avatar
COTM Editor
Post up the pics of your car man!
Old Aug 30, 2012 | 01:23 PM
87350IROC's Avatar
Car: 87' IROC
Actually its not to hard at all. By the time you make the back pad on the front wheel large enough for a modern flat style wheel to cover the spindle snout, you end up with a pretty small lip. And the rear lip ends up roughtly 1" larger than the front. Of course you will not get the 4-6" lip some of the Pro Touring guys are running. At least not without some more involved modifications.
Old Aug 30, 2012 | 01:35 PM
BOTTLEDZ28's Avatar
Transmission: A4
So if I understand your post correctly, you are basically doing exactly what a spacer is intended for. The way I see it, and someone correct me if I am wrong, but the only way to get "that look" above is to narrow the rear end slightly and move the spindle location outward slightly on our cars
Old Aug 30, 2012 | 01:38 PM
BOTTLEDZ28's Avatar
Transmission: A4
Just look at the lip on the GTA wheels. The fronts are deeper then the backs.
Old Aug 30, 2012 | 02:03 PM
I'm not sure of the specs.... Jason is handling it. I ordered Baer brakes from him as well. I believe that changes things a bit. (at least in the rear) I trust Jason's judgement when it comes to the final specs.
Bottom line, I'm a business man and he builds wheels for a living. He knows the car, knows the wheels.....there is no doubt in my mind that when they arrive they will be perfect.
I will get pics up this weekend and as soon as I get the car back from the engine shop... Cant wait to see that stroker under the hood myself!
Oh....and I went Rated-X! Black centers with polished lip.... Should look mean if you ask me.
Old Aug 30, 2012 | 02:06 PM
Car: 1991 Firebird
Engine: 3.1L V6
The fronts are "deeper"/have a different offset than the backs so they don't rub the strut(correct me if i'm wrong)...if you've ever tried putting a back wheel on the front, you'd know what i'm referring to. I have 18x9/35mm/2.75" lip on the front of my car, and 18x10.5/20mm/4.25" lip on the rear. The front, I did need a 1.25" spacer. As 87350IROC said, the hub was an issue, till I put the spacers on. The rears fit perfect, minus some fender massaging with a hammer, no spacer needed.
Back to topic... I say go for the Rated-X. They look good, and you don't see those on 3rd gens. Plenty of 3rd gens with the mesh style wheels, including me.
Old Aug 30, 2012 | 02:08 PM
Car: 1991 Firebird
Engine: 3.1L V6
Very nice, look forward to seeing it all together.
Old Aug 30, 2012 | 02:09 PM
These wheels are being custom made. No spacers will be required.
Old Aug 30, 2012 | 02:28 PM
87350IROC's Avatar
Car: 87' IROC
I hear ya. But there is a ton of knowledge on here. In my opinion I would get the specs from Jason and share here. It just makes sense on a $2k+ purchase. I see this all the time on other forums where wheel sponsors are common. Occasionally the wheels come back and the customer is unhappy.
Make sure you also understand the lip sizes. You will not get the lip size seen on that first gen. And finally the front spindle clearance.
Just trying to help, I have been down the custom wheel route and there are a lot of considerations.
Old Aug 30, 2012 | 02:34 PM
I have to call him tomorrow morning. As soon as I get them I will post....and believe me, all input is welcomed. My knowledge is limited at best...
Thanks,
Old Aug 30, 2012 | 03:03 PM
87350IROC's Avatar
Car: 87' IROC
No, that is not what I'm talking about. A couple of considerations.
Aftermarket brakes will widen your front track which reduces the front lip.
Our spindles stick out very far from the wheel mounting surface. Modern wheels have a very flat surface in the center hub area. Whereas old school wheels have a snout that covers the spindle. For this reason the back pad needs to be thick in order to cover the spindle. This again means a reduced front lip.
On the rear. The OEM rears are tucked in a little more than I like. So right there is a opportunity to increase the rear lip. Plus there is no spindle to deal with or extra brake thickness.
At the end of the day I ended up with a 2.0" front and 3.0" rear lip. Lots of considerations.
Old Aug 30, 2012 | 03:46 PM
BADNBLK's Avatar
COTM Editor
Perfect with stock width! Can't wait to see your set up on with all its brushed goodness!
Jason will take car of you!
Old Aug 31, 2012 | 11:14 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I'd go with the rated X. I almost went that route before the sickness set in.
Old Aug 31, 2012 | 11:58 AM
BADNBLK's Avatar
COTM Editor
Would be my choice as well!
Old Sep 5, 2012 | 01:04 PM
BADNBLK's Avatar
COTM Editor
What did you pick???
Old Sep 5, 2012 | 01:15 PM
Car: 1991 Firebird
Engine: 3.1L V6
Good choice.
Old Sep 5, 2012 | 01:44 PM
Engine: 305 to 350
Axle/Gears: 10 Bolt
Any new pic of camaro yet ?
Old Sep 5, 2012 | 01:46 PM
BADNBLK's Avatar
COTM Editor
Originally Posted by CharcoalBird
Good choice.
Thanks dude... I missed that somehow. I wanna see these babies on a third gen.
Make sure you post pics!!!!
Old Sep 16, 2013 | 10:59 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
I guess there's one.
https://www.thirdgen.org/forums/whee...18x10-6-a.html
Loudnproud86
Jul 14, 2016 12:59 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
DonW
Carburetors
Sep 23, 2015 08:04 PM
aharvel50
Sep 21, 2015 07:31 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
