Dual bolt pattern hubs. 5x4.75" and 5x120mm for BMW and Modern GM wheels
Old Jan 9, 2013 | 01:47 AM
87350IROC's Avatar
Car: 87' IROC
Hi folks, I had these made for someone and just wanted to pass on the idea. I do have a few extra sets if anyone needs any.
They are drilled for both our stock 5x4.75" bolt pattern and the BMW and modern GM 5x120mm bolt pattern. This would be a good option for someone running BMW or Camaro SS wheels.
They also use the larger 1LE outer bearing (SET3). They are made of 6061-T6 aluminum and are black anodized.
Thanks,
John
Old Jan 9, 2013 | 08:30 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Dual bolt pattern hubs. 5x4.75" and 5x120mm for BMW and Modern GM wheels
What do you charge for a set of these? Also. what type of spindles do these mount on?
Old Jan 9, 2013 | 09:26 AM
87350IROC's Avatar
Car: 87' IROC
PM sent regarding pricing.
They work on the stock spindles. They do use the larger 1LE outer bearing. This bearing has the same inner diameter as stock to fit on the stock spindle pin.
Hubs include ARP studs, Timken bearings and seals, and dust caps.
John
Old Jan 9, 2013 | 11:19 AM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Very nice!
Old Jan 30, 2013 | 01:16 AM
87350IROC's Avatar
Car: 87' IROC
Finally got a break in the weather a took a few better pictures.
Old Jan 30, 2013 | 01:29 AM
caffeine's Avatar
Car: 89 Firebird Formula
Engine: 3500T
Axle/Gears: 9 bolt/4.11
I'm also interested in price. These would be used with a brake upgrade, right?
Old Jan 30, 2013 | 02:00 AM
87350IROC's Avatar
Car: 87' IROC
Private message sent.
Yes, these are for brake swaps only. They are the same offset as OEM integral hub/rotor.
They include:
Timken bearings
Timken seals
ARP studs
stamped dust caps
billet dust caps (+$35)
Old Jan 30, 2013 | 04:02 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
These are awesome
Old Jan 30, 2013 | 04:51 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
wow nice, i wonder how much these would run
Old Jan 30, 2013 | 06:37 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Price please.
Old Jan 30, 2013 | 09:03 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
So just to be clear, by running these and the supplied bolts, one could run either 120 or 120.65 wheels?
Old Jan 30, 2013 | 09:13 PM
gp90gta's Avatar
Car: 1990 GTA
Very nice, I'm intreated, If you could PM me a price please, thank you.
Old Jan 30, 2013 | 10:46 PM
87350IROC's Avatar
Car: 87' IROC
Yes.
The hubs are drilled for both 5x4.75" (120.65mm) and 5x120mm. You tell me which wheels you plan to run, I install the studs in the correct holes and ship the hubs to you. If later you change wheels to the other bolt pattern, you would knock out the studs and re-install them in the other set of holes.
Old Jan 30, 2013 | 10:51 PM
87350IROC's Avatar
Car: 87' IROC
I was trying to not post the price here, as I'm not sure if it is allowed, but have received enough interest.
Price is $435 shipped to the lower 48.
Price includes:
Hubs - 6061 T6 AL, anodized black
ARP 12mm wheel studs
Timken bearings (SET6 and SET3) - larger 1LE sized outer bearing
Timken seals
stamped steel dust cap (billet aluminum caps are +$35)
The hubs are 4lbs lighter each than an OEM rotor modified into a hub. Hubs are the same offset as OEM rotors modified into a hub.
John
Old Jan 31, 2013 | 09:21 AM
Car: 91 RS
Engine: 350 TBI
Which is what exactly?
Old Jan 31, 2013 | 09:57 AM
87350IROC's Avatar
Car: 87' IROC
Really, the offset is generally defined from the hub or rotor surface. So its hard to define what exactly the offset of the hub is. I think it is useful to compare it to OEM since that is what everyone understands.
So these place the hub surface in the same place as the wheel surface on the OEM rotors.
To be more specific the distance from the edge of the spindle snout to the hub mounting surface is 2 9/16" when installed.
John
Old Jan 31, 2013 | 10:29 AM
Car: 91 RS
Engine: 350 TBI
John
And though you state these are for 1LE brakes, I guess that really means they'll work with any larger brake set up . . . . such as my Baer kit or the 5th Gen brake kit?
So really what this does is act as an adapter therefore allowing those who want to run BMW wheels don't have to get hubcentric rings or wobble nuts . . . and allows us to switch back to 120.65 wheels in the future if we so choose?
. . . that's the down and dirty, Barney version I suppose???
Old Jan 31, 2013 | 11:13 AM
87350IROC's Avatar
Car: 87' IROC
I think I may have added some confusion with the 1LE bearing thing.
These are the same offset as the OEM 10.5" brake rotor. However I had them machined for the larger 1LE SET3 outer bearing. So you get all the advantages of the 1LE bearing without the extra offset.
Now what you need for brakes depends. Many kits (any Vette, LS1, Wilwood) use an OEM rotor turned down to a hub. Others (1LE, 5th gen, 09+ CTS-V) require the extra offset of the 1LE hub in order to use an adequate thickness caper bracket. In this case you would use a 1LE rotor and turn it down into a hub.
So to clarify my hubs here work great on kits that normally use the OEM rotor as a hub. However my hubs have the following advantages over using an OEM rotor:
- larger outer bearing
- dual bolt pattern
- 4lbs lighter each
My hubs can be used for the brake kits that normally use the 1LE but using a spacer between the hub and rotor. This is not ideal of course, but I don't see a major issue with it. I can do customs with "any" offset but the cost begins to skyrocket for one off sets.
There are discussions on the whole hubcentric and wobble nut deal on here. I won't get into it here. If you are interested I can dig it up. In short, hub centric rings do NOT fix the problems associate with running wheels of the wrong bolt pattern for the car (wheel studs in bending). Wobble nuts do solve the issue of wheel studs in bending but now you have lost the locating ability of the lug nuts. In this case you would need to have a very good hub centric fit to center the wheels. I personally would not run these on my vehicle.
Another good solution is to re-bore wheels to the correct bolt pattern as //<86TA>\\ has done.
Frozer!!!
Jan 19, 2024 04:55 PM
beastin91rs
Oct 9, 2015 07:38 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Dialed_In
Aug 20, 2015 01:45 PM
