What spacer needed for a 32mm offset?
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
Found a sweet deal on some OZ wheels and tires, I know the 5x120 will fit our 5x120.65, but I'm wondering what spacers I need to get a 32mm offset to fit.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: What spacer needed for a 32mm offset?
couldn't tell you without knowing the width of the wheel.
Engine: LB9, LB9
you'd probably want to end up with a +0 to a -10 offset. so something like a 35mm-40mm adapter. to make it easy I'd say a 1.5" adapter which translates to 38.1mm.
Engine: LB9, LB9
some all around unless you're running aftermarket brakes.
Engine: 305 LB9
no aftermarket brakes, I just want to have my wheels function and look correct.
looks like these are the way to go, no?
http://www.performancewheeladapters....0-Wheel/Detail
Bolts right on, had 8.5 et 35s on mine. Tucks in, et20 is a better fit....or even 15
Nice
