Will 285/70R15 fit?
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Will 285/70R15 fit?
Not likely. Thats a 31" truck type tire size. Width would have been ok but wayyy to tall
Car: 89 Iroc-z
Transmission: TH400
It would take serious work getting that to fit. It may be possible but require a ton of well rework to keep it from contacting the tire as suspension travels. Guys have done 29-30" tall tires before but not sure how modded the fenders were
Car: 1985 Camaro Z28
Engine: Work In Progress
Transmission: 700R4/2200 stall/Shift Kit
Axle/Gears: 7.5 Richmond 3.73/Gov Loc Posi
Alright thanks. Do you know what the stock stud size? and would you happen to know where I can get the correct uni lug nut kit for a set of american racing slotted mags?
Car: 89 Iroc-z
Transmission: TH400
No idea on lugs but stock studs should be 12mm x 1.5 thread i believe. May want to double check that thru a search here
Alright thanks. I'm just in need of wheels and tires for my car and I am looking for any set that can fit a 275/60R15 in the back. I'm probably just going to save my money for some Summit look a like weld pro stars and the tires. But it would be amazing to find a used set.
Car: 89 Iroc-z
Transmission: TH400
275/60 has a better chance at fitting. Guys run that all the time. 285/70 is a heck of alot taller
Right. I just saw a good deal on craigslist but I decided I'm not going to get them because of the fitment issues.
New2Chevy
Sep 28, 2015 12:35 AM
