New 19" Wheel Fitment
Old Dec 30, 2013 | 07:28 PM
mikeirocz1's Avatar
Car: 91 RS and 88 IROC-Z
Engine: 305 TBI and 383 Carb
Transmission: 700R4/2200 stall & 700R4/3500 stall
Axle/Gears: 3.42 posi and 4.11 posi
I'm looking at purchasing a set of wheels and am needing some advice on the fitment. The front is 19x8.5 with +46 offset and the back is 19x10 with +48 offset. I'm running a rearend from a 97 transam. Will I need spacers all the way around or just the front? I plan on running 245-35/19 and 295-30/19 tires.
Old Dec 31, 2013 | 12:06 PM
86iroct5's Avatar
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Re: New 19" Wheel Fitment
just the fronts
Old Dec 31, 2013 | 01:52 PM
mikeirocz1's Avatar
What size for the front, 2"?. With that offset and 97 rearend will the back wheels stick out past the fenders?
Old Dec 31, 2013 | 05:48 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I'm going to suggest (if possible) that you pick up (4) 10" wide wheels so you can run a 275 (or 285 all around).
Old Dec 31, 2013 | 07:48 PM
mikeirocz1's Avatar
I'm running 17x9.5 with 285-40/17 on my IROC-Z with a stock rear. Im looking for my RS and it has a 4th gen rear with 19's and 245-35/19. I need tires but am thinking about getting different wheels which I found on craigslist for a good price and new tires. Im also thinking about trying to go 11" wide and going back down to 17's or 18's but Im not sure on the backspacing to fit a 11" wide wheel with a 4th gen rear and keep the wheel tucked.
Old Jan 1, 2014 | 06:17 PM
mikeirocz1's Avatar
Can anyone help me with the correct backspace / offset to run with the 4th gen rear to get as wide as possible and still stay tucked? I would like to get a good size lip on the back. Right now all 4 wheels are the same size without any lip and Im running spacers up front
Old Jan 3, 2014 | 03:51 PM
mikeirocz1's Avatar
Can anyone help me with the offset/ backspacing? Would 19x8.5 and 19x9.5 with 35mm offset on both work with the 4th gen rear and spacers up front??
Old Jan 3, 2014 | 11:55 PM
sparkm1's Avatar
I have a question on this subject. i have a 91 firebird that i am restoring and recently put a set of the yearone snowflakes with 275/40/17's up front, others with these rims have posted they would fit. They are rubbing like crazy and even hitting the frame at full lock. the guy that is doing the work is pretty good but not necessarily a third gen expert. it has a new front end and new suspension and has been lowered. he has tried multiple spacers and nothing works. he looked up the wheel, which is made for 2nd gen, and he believes this is the issue. any suggestions? will 245's solve? raise it back up?
Old Jan 11, 2014 | 02:28 PM
mikeirocz1's Avatar
Can anyone help me??
Old Jan 12, 2014 | 10:11 AM
mikeirocz1's Avatar
My options are 19x8.5 with 35-38-40 or 45 offset for the front and 19x9.5 with 35-40-45 or 48 for the rear. Im looking to get the most lip on the rear without sticking out past the fenders and I have a 4th gen rear from a 97 firebird. I want to try and run 255-35/19 front and 295-30/19 back.
Old Jan 12, 2014 | 10:20 AM
mikeirocz1's Avatar
I also already have a set of 1.5" spacers that I can use for the front if needed.
Old Jan 14, 2014 | 04:17 PM
mikeirocz1's Avatar
Is anyone running a 295-30/19 with 4th gen rear. If so, what size wheel and backspacing / offset?
Old Jan 14, 2014 | 04:41 PM
Twin_Turbo's Avatar
I run 19x8.5 ET15 and 19x9.5ET20s they do not stick out, in fact the front could take even less offset and this is with a brake upgrade pushing the hub face outboard. Adjust for the rear axle you have, fronts should be spot on. ETs in the 40s require spacers.
I have a 295/30/19 in the rear but not a 4th gen axle, however with the correct wheel offset it's not a problem. I run 265s in the front and next time I would go 275 front and 315 rear...I think I can make that fit without a problem.
Old Jan 14, 2014 | 06:30 PM
mikeirocz1's Avatar
I run 285-40/17 on a 9.5 with 5.5 backspacing on my 3rd gen rear without any issues. So I need to run 17x9.5 with 7 1/2 backspacing with the 4th gen rear since its 2 inches wider?
Old Jan 14, 2014 | 06:50 PM
Twin_Turbo's Avatar
it's 1" per side... so 6.5BS although that really sounds like a lot. On a 9.5 wide rim that's about 1.5" of offset (it's actually not accurate since rim width and offset take different dimensions off a rim, one the rim edge and the other the tire bead)
This is a pic of the 19s in the sizes I listed. I run Vredestein Ultrac Sessantas and they are a little on the narrow side for 295s, I swear the old Good Year 295s I had were wider/
Old Jan 14, 2014 | 07:26 PM
mikeirocz1's Avatar
Whats the specs on those wheels? Is that a 3rd gen or 4th gen rear? Some sites offer offset and some offer backspacing numbers. And some have both. Im just not real clear on what to go with on the 4th gen rear.
Old Jan 14, 2014 | 08:08 PM
mikeirocz1's Avatar
Sorry, I noticed you listed the specs above. So if I wanted to run that same setup I would just do it with a 1" of extra backspacing since I have the 4th gen rear?
Old Jan 15, 2014 | 02:13 AM
Twin_Turbo's Avatar
yes
Old Jan 20, 2014 | 01:55 PM
blue84transam's Avatar
Is this lowered or stock ride height? I am looking at having an 18x9 up front, 19x10 rear on my trans am, I love the stance of this.
Old Jan 20, 2014 | 04:47 PM
Twin_Turbo's Avatar
lowered
Old Jan 20, 2014 | 05:25 PM
lowered
What are you lowered on? Any issues with the wheels/tire fitment with it?
Old Jan 20, 2014 | 06:16 PM
Twin_Turbo's Avatar
eibach sportlines, no fitment issues, doesn't rub. Frt has C5 calper conversion. I will do a Z06 caliper soon, need to bring the wheel out 1cm for that, will see if it rubs on full lock then
Old Oct 27, 2019 | 11:38 AM
Terence Zelman's Avatar
Car: 1987 Iroc Z
Engine: 5.7
Transmission: 4 speed auto
what wheels are those? That’s the nicest looking aftermarket wheel I have seen on a 3rd gen.
Old Oct 29, 2019 | 03:03 AM
Twin_Turbo's Avatar
BMW wheels. Röwhe concave
Old Oct 29, 2019 | 06:38 AM
Car: 1987 Iroc Z
Engine: 5.7
awesome. Thanks.
z 28 jari
Sep 14, 2021 10:03 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Chad Speier
Sep 24, 2015 12:32 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
