change of plans.
Old Mar 24, 2015 | 10:21 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
change of plans.
Hi guys, back again with a few questions.
1st off does anyone have these on their car? Would love to see them.
2nd I think I need 2 in wheel spacers. Where is the best place to get them? Just spacers though right?
Last is once I get a 4th gen rear I won't need spacers in the back correct?
http://www.oewheelsllc.com/Wheels_3/...T#.VRFgtZ_D_qB
Thanks for your time
Old Mar 26, 2015 | 02:13 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: change of plans.
Also if you guys could suggest a good tire for them. My ultimate plan is to run the 4th gen rear so the rear tire will have to work with the 3rd gen wit spacer and the 4th gen.
thank you
Old Mar 30, 2015 | 07:26 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Those are sweet wheels
Old Apr 2, 2015 | 10:16 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Kinda what I was thinking but was really hoping some1 had some pics and can't confirm everything including tire size before I buy them
Old Apr 5, 2015 | 07:25 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Nobody has these wheels?
Can someone confirm the spacers, rear,and tire size?
Old Apr 5, 2015 | 07:48 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
On the front, you need 2.00" spacers.
275-40-17 is the correct tire size.
Old Apr 7, 2015 | 07:44 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Thank you. The rear would be the same as long as I keep the stocker right?
Old Jul 5, 2015 | 09:26 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
So the original wheels I wanted are still not in stock. These wheels are option b and are on sale!
Just wanted to make sure 275 40 18s will work too since they're slightly different.
Also those of you with the spacer/ adapters. Who do you recommend? Anyone special on ebay? And I anything special I need to look for?
thanks on advance
http://www.oewheelsllc.com/Wheels_3/...T#.VZk9yp_D_qB
Old Jul 5, 2015 | 09:30 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
http://m.ebay.com/itm/271921590135?nav=SEARCH I was thinking on using these.
Old Jul 8, 2015 | 03:42 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Anybody have inputs on either tires or spacers? Plan on getting these soon just wanna make sure I'm not wasting money.
Old Jul 13, 2015 | 06:00 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Well I just picked up a 99 trans am rear. Shortly I'll have that in and I'll run my gta wheels till I get a set of vette wheels. Can anyone chime in on the tire size for those wheels?
Old Jul 14, 2015 | 11:11 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Axle/Gears: 10 Bolt 4.10
You can't run an 18 inch tire with a 17 inch wheel, if that's what your question is.
275/40/17 is the correct size.
275/40/18 is meant for a completely different size of wheel, and will not work.
Old Jul 14, 2015 | 11:13 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
Also, I have a 99 Trans Am rear in my car. The width is equivalent to a stock thirdgen rear with 2" spacers. I used to have C6 Corvette wheels and they fit perfect on the rear without spacers, you'll still need 2" on the front.
Old Jul 15, 2015 | 05:45 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
http://www.oewheelsllc.com/Wheels_3/...T#.VaY4jZ_D_qC
These are the 18s I'm talking about. Completely different and on sale! Lol. I just wasn't sure as far as what tires to run.
I wasn't planning on trying to fit a 18 inch tire on a 17 inch wheel. Sorry if it came out that way.
IF I get 17s the tires would be 275/40/ 17
just curious what the 18s would be?
Yes i know I'll need spacers in the front still was just asking opinions on the ebay spacers. I no longer need 4 since I have the 4th gen rear.
Old Jul 15, 2015 | 02:00 PM
Skinny Neb's Avatar
Car: 1985 Trans Am
Engine: 385
275/35/18. I bought my spacers second hand so I can't shed any light on that.
Old Jul 15, 2015 | 02:12 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Go with an 18" wheel and you will have much less to worry about with the tie rod ends. I had to run a 2 1/8 or 2 1/4 spacer up front with 17.
Old Jul 15, 2015 | 09:04 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Ok, yea 2 in spacers I was told just not sure which. Also not sure in the tire size. I'd like it to sit close to stock height. My longtubes are the lowest point atm
Old Jul 24, 2015 | 11:10 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
So I just got me a set of these ordered!
I was thinking about 275/35 18s for these.
Suggestions on where I should get my 2 in spacers for the front?
Old Jul 24, 2015 | 12:39 PM
Tibo's Avatar
Car: 1991 Z28 Vert
EBay. They won't be hubcentric, instead they will be centered with the studs. It may put more stress on the wheel studs but I've put over 50,000 miles on my fronts including autocrossing and haven't had a problem yet.
Old Jul 24, 2015 | 04:47 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Ok. Any specific seller or just one that has the 2 in spacers?
Also curious if any with the 275/35s experience any rub in the front? Figured it made more sense to be able to rotate them.
Old Jul 24, 2015 | 06:41 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I have 275/40/17 and they rub with the steering wheel locked but to be honest that's only in parking lots. On some autocrossing courses taking a hard turn and braking would bring it but that could be too little suspension travel. When you bolt them up and set the car down, make sure you have 1/4" clearance between the rim and strut body.
IROCtometal
Sep 20, 2015 11:08 PM
64goatman
Sep 9, 2015 01:09 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
luvofjah
Sep 3, 2015 07:08 PM
