bmw wheels .
Old Oct 20, 2019 | 03:10 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
bmw wheels .
i been looking at wheels for my 88 iroc . the bmw wheels has a 5-120 bolt pattern . will this work .? i understand i will need spacers
thanks inadvance guys
Old Oct 21, 2019 | 08:49 PM
K_trip's Avatar
Car: 1985 IROC-Z
Engine: 5.0 Liter H.O. (carb)
Transmission: T5 5 speed
Axle/Gears: open 3.73
Re: bmw wheels .
It's not the same bolt pattern, close enough it could be made to work.
I wouldn't use them - I saw this a little while ago (made them work)...
https://www.thirdgen.org/forums/whee...t-pattern.html
Old Oct 22, 2019 | 02:48 PM
K_trip's Avatar
Car: 1985 IROC-Z
Re: bmw wheels .
If you are going to run "spacers" anyway, another approach is to use an "adapter" instead. The car doesn't need to change, nor does the wheel, just have a "spacer" with both the needed bolt patterns. I know custom ones can be made. I'm not sure if there is anything "off the shelf" but it's likely...
https://www.uswheeladapters.com/5-lug-wheel-adapters/
Old Oct 22, 2019 | 09:42 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
Re: bmw wheels .
I just went through all of this. You will need spacer/adapters 4.75 GM to 5x120mm BMW. I met this guy on eBay and will be buying them from him:
https://www.ebay.com/usr/tireshopsupplies?ul_noapp=true
He recommended hub centric adapters that are on both sides of it. One for the stock center hub and one for the BMW rims. Really cool guy to talk to. I am getting 1.5" thick for up front and 3/4" for the back. The rims I have a +35mm, being my bird is +16 up front and 0mm back. Also, get a 245/40 18 tire. This is 26" wide which is very close to the 245/50 16 tires my bird has anyway. My rims are JNC026 8" wide.
Customer Support
Mon-Fri 7:30am-4pm PST
Phone: (909) 890-0092
Address: 367 E Redlands Blvd San Bernardino CA 92408
Old Oct 23, 2019 | 07:46 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: bmw wheels .
thanks guys
Old Oct 23, 2019 | 09:38 AM
Engine: 5.7
Axle/Gears: Stock
Re: bmw wheels .
Originally Posted by freaky
thanks guys
Good luck on getting them installed, POST PICS!!
Old Oct 24, 2019 | 09:41 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: bmw wheels .
yeah ill post pics an all . maybe in jan
Old Nov 4, 2019 | 05:07 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: bmw wheels .
found these xxr 526 . i think im going
with these
Old Nov 6, 2019 | 03:23 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: bmw wheels .
yea couple have those rims in the forum
Old Nov 7, 2019 | 03:39 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: bmw wheels .
yeah i really like the way the xxr 526 look on the third gen .
Old Nov 13, 2019 | 06:02 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Re: bmw wheels .
Yes, BMW wheels work nicely. Look at post 2419.
https://www.thirdgen.org/forums/whee...rd-gen-49.html
I used wheels for a M5. The 3 series have the wrong off set. I used a 6mm spacer on the front and 10mm on the rear. When I had my Moser rear built I had the extra width built into it but it worked with the spacers also. I did install longer lug studs with the spacers to be safe but it works either way.
The BMW wheels are on a 112 BC which is 0.020 larger than 4 3/4" but it's not been a problem for me. Just make sure you torque wheels evenly and low to high to make sure they pull in correctly since it is now lug-centric. The hubs centers don't line up.
Old Nov 14, 2019 | 12:07 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
Re: bmw wheels .
i like those . what size tire is on it ?
PAFORM350
Wheels and Tires
Feb 21, 2020 08:52 PM
88ragtop
Feb 19, 2007 10:50 PM
android
Jun 29, 2006 12:12 PM
My90Iroc
Jul 22, 2003 06:31 AM
