Rear tire clearance.
Old Sep 26, 2022 | 05:34 AM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
I have a 4th gen rear running an 18x10.5 wheel with a 56 mm offset. I installed 305/35 nittos. There is maybe 3/16 gap between the tire and the inner front wheel well. I’m thinking a 1/4 spacer on each side would work. How much does the rear move around when the suspension is working? Should I get a bigger spacer?
Old Oct 1, 2022 | 03:01 PM
tomsaddy's Avatar
Car: 1987 GTA
Engine: TT LC9
Axle/Gears: 3.50
Re: Rear tire clearance.
I would start with what you have. Make sure the wheel well has nice new clean paint, then drive around a little. If you rub the paint off anywhere, then you either need to work the sheetmetal or use a thicker spacer.
I probably have about 1/8” clearance and I rub once on a while. I have a 4th gen rear, 19x12/59mm wheels with 325/30 Michelin Pilot Super Sports. I needed to notch the area where you’re rubbing. Pics in my build thread (link in signature).
Evilokc
Jan 6, 2020 06:08 PM
gpetry
Wheels and Tires
May 15, 2013 08:39 PM
hardyz13
Wheels and Tires
May 22, 2010 09:19 PM
hung4wheeler
Apr 28, 2008 11:19 PM
black84z28-4spd
Dec 22, 2005 03:54 PM
