235/70/15 vs 215/65/15 on 84 trans am. Will it fit?
Old Dec 30, 2025 | 09:05 PM
chesee48's Avatar
Car: '19 Blazer RS/ 84 TA/ 94 Z-28
Current have the 215/65 on and wondering if the 235/70 will be ok?
Old Dec 31, 2025 | 02:17 AM
LAFireboyd's Avatar
Axle/Gears: 9-bolt/3.45
Re: 235/70/15 vs 215/65/15 on 84 trans am. Will it fit?
235/70 is 2" taller than the factory size. It'll fit the wheel, but it's likely to scrape inside the wheel wells, at least, according to a recent post by someone who has 28" tires and said they scrape, and he was looking for something else. The optional 15" size from the factory was 235/60. It's the most appropriate 15" upgrade.
Old Dec 31, 2025 | 04:27 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
They will also make your speedo read slower than you're actually going...
Old Dec 31, 2025 | 07:54 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
They will be much taller, probably rub and look goofy.
235/60R15 is the same height as the 215/65R15 and they fit without rubbing. They were an optional size for a couple of years.
Old Dec 31, 2025 | 10:07 AM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
I put 215/70R15 97S M&S, BF Goodrich, Radial T/A tires on my 1986 Firebird and had to pull back the inner fenders on the front as the tires rubbed when cranked full left and right. I pulled the inner fenders back with a piece of threaded rod and it solved the rubbing issue. Your 235 tires will be wider and I think they might be too large to fit. The taller profile tires raise the car a little and make it a bit easier to get in and out for my old knees.
To me the car looks better with the taller tires as it fills up the wheel wells better.
Keep in mind that with the taller tire you will be travelling faster than with stock tires at the same speedometer reading, because the circumference of the tire is longer per revolution.
Old Jan 1, 2026 | 03:03 PM
chesee48's Avatar
Thank you everyone! I was trying to buy the cooper cobra tires and this size was available locally on fb marketplace
Old Feb 15, 2026 | 03:09 PM
chesee48's Avatar
Would 245/60 fit ok in the rear?
Old Feb 15, 2026 | 03:58 PM
Car: '89 GTA
Engine: ZZ6TPI
They will fit, I’ve seen a number of people run that size on the rear. A little bit taller than stock.
Old Feb 15, 2026 | 04:25 PM
chesee48's Avatar
215/70 on front and those in the back would work?
appreciate the feedback!
Old Feb 15, 2026 | 04:35 PM
Car: '89 GTA
Engine: ZZ6TPI
Not sure about clearance in the front. Might rub the fender liner when the wheel is turned.
Old Feb 19, 2026 | 08:08 PM
chesee48's Avatar
Just to double check- on stock 15inch rims, 215/65, 235/60 and 245/60 are all the options?
Old Feb 19, 2026 | 09:34 PM
T.L.'s Avatar
The rims are 7 inches. The wheels are 15 inch. Yes, those are the best tire size options...
Old Feb 19, 2026 | 10:27 PM
chesee48's Avatar
Thats what I meant with the wheels, thank you!
Old Feb 21, 2026 | 08:45 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
I have run 255/60-15 on the stock wheels on the rear as well.
Old Apr 6, 2026 | 11:05 AM
chesee48's Avatar
Will 255/60/15 not fit on the front? I see someone selling a set of 4 locally. Otherwise I was going to meet someone further for a set of 235s
Old Apr 6, 2026 | 11:24 AM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
235/60 R15 is the tire size you should run on your factory 15x7 wheels.
Old Apr 6, 2026 | 11:34 AM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LH0
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
I ran 245/60/15s on my '92 for awhile, until I switched over to 16s so I could fit LS1 brakes. The rears fit without issue, but the fronts rubbed a fair bit at full lock. I ended up putting spacers (1" I believe) on the front wheels, and that pretty much fixed it... slight rub at full lock to the left, but no issues in normal driving outside of parking lots. Check your rear bump stops while you got the wheels off btw, you'll be scrubbing the top of your wheel well every time you drive through a dip if yours are rotted off like mine were!
I have some pictures of my car with the 245s installed, you can see them if you go to my profile and check the "post-accident pics" album. The white letter tires were the 245s, good ol' Cooper Cobras
Old Apr 6, 2026 | 11:50 AM
chesee48's Avatar
thank you. I won’t go higher than the 235s then. Thanks!
72buickgs
Wheels and Tires
Oct 22, 2021 08:03 PM
Jproz1167
May 11, 2004 01:19 PM
trans_am_ta_84
Apr 4, 2003 08:14 AM
BillZ28
Nov 16, 2002 12:49 PM
IROC-ZTWENTYGR8
Oct 9, 2000 04:35 PM
