Under Hood Permanent Fuel Pressure Gauge
Old Nov 4, 2003 | 08:21 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I did a search and didn't find mu on what I was looking for. Anyhow.....I've heard that the fuel pressure guage that Acell makes isn's supposed to be mounting under the hood permanenty because it's not liquid filled. Summit has a fuel pressure guage that is liquid filled and it's only $19.95:http://store.summitracing.com/partde...t=SUM%2D800199
It's say's" adapter sold seperatley".,.....how do I know what adpater to get? I have NO clue on what kind of fittings or adapters to get, also.....where does it hook up too?......can anyone please help me out?? ANY into would be great Thanks
Old Nov 4, 2003 | 02:43 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Under Hood Permanent Fuel Pressure Gauge
I just sent my Accel back for the reason you stated. I just ordered a liquid filled gauge for permanent mounting from Street and Performance. It was only 50 bucks. Its good for 60psi as well, just like Accel. The web site is www.hotrodlane.cc/. Click on "online catalog" at the top or just call and ask for the tpi fuel rail liquid filled gauge. You get what you pay for! I wouldnt buy the Summit gauge for 19.99.
Old Nov 4, 2003 | 03:19 PM
Engine: 5.7
Re: Re: Under Hood Permanent Fuel Pressure Gauge
does it come with the fittings and everything necessary to install it?
Old Nov 4, 2003 | 03:50 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
Why can't you use a permanant gauge that's not liquid filled? The Accel one is sold as a permanent install.
Just wondering, cause that's what I installed earlier this summer
Old Nov 4, 2003 | 04:00 PM
Engine: 5.7
In summit....is says not for permanent use. Does anyone know if I need to get some kind of line or something to run one of these gauges? It looks like if I just mount the guage where the shrader valve is.....there isn't going to be enough room for the guage to fit. It looks like it would hit the runners and the plenum.....I thought maybe if a could run some kind of line from the shrader valve...so I could put the guage further out.
Old Nov 5, 2003 | 12:22 AM
there is enough room to install the gauge. you dont need anything else, it comes with everything you need.
Old Nov 5, 2003 | 08:15 AM
Engine: 3.0
Where? I was just on their site to check this and don't see any mention of this.
It stands to reason that a fuel pressure gauge mounted on the fuel rail is a permanent install, because it screws right onto the schrader valve.
There is plenty of room to install it. Fits like a charm, just make sure your buy the right one, i.e. for TPI engines.
Old Nov 5, 2003 | 09:01 AM
Engine: 5.7
it's weird because it dosen't say anything about it on their website.....but it says it in their catolog..
Old Nov 5, 2003 | 09:15 AM
Scottlb9's Avatar
Car: 1991 Formula
Engine: 5.0 TPI
I was looking at the Accell one also. Whats the difference between liquid and non liquid filled?
What is wrong with the Accel one?
Accel Fuel Pressure Gauge
Old Nov 5, 2003 | 09:37 AM
Engine: 3.0
I've been using the Accell one since early this year...no problems at all.
Old Nov 5, 2003 | 01:51 PM
Engine: 5.7
I would email summit and ask them.....I think I might go ahead and do it to see what they have to say.
Does it come with all of the necessary fittings to install the accel guage?
Old Nov 5, 2003 | 02:10 PM
Engine: 3.0
everything is supplied, took all but 10 minutes to install...much cleaner and easier than a hand held guage.
Old Nov 16, 2003 | 02:50 PM
Engine: 5.7
Hey CaptPicardsZ28, that TPI Fuel Pressure gauge that you purchased from Street and Performance....does it read up to 60 PSI?? It looks like a nice gauge....I'm running MAP, will the gauge still mount on the fuel rail with the MAP sensor right there? The shrader valve is pretty close to the MAP sensor...
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
