4th gen driveshaft
Old Feb 16, 2004 | 04:43 PM
JamieGirl89RS's Avatar
Car: 89 RS
Engine: It had a 350 put in it.
4th gen driveshaft
Does anyone know if the 4th gens have aluminum driveshafts and would they work in a 3rd gen with a 700R4?
I frequently go 80mph+ in my 89 Camaro and it vibrates a good bit. Someone told me that an aluminum driveshaft would take care of the problem, but the local used parts place only carries parts from 10 years back, so I would ask them for a driveshaft from a 94 Camaro or something I guess, but I want to make sure it will work first.
Thanks!
Jamie
Old Feb 16, 2004 | 05:12 PM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
From what I checked out, all driveshafts from 1982- 2000 are the same no matter what trans.
Old Feb 16, 2004 | 05:37 PM
vwdave's Avatar
Oh really?
The LS1's had aluminum driveshafts, the LT1's did not. Get a driveshaft for a 98-02 Camaro/Trans Am.
(Edit) Info fixt.
Old Feb 16, 2004 | 06:25 PM
pasky's Avatar
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
manuals are not a different length. Only thirdgen I can think of that won't fit are the older 82-83 thirdgens.
Old Feb 16, 2004 | 06:41 PM
vwdave's Avatar
I was told that when I was going to swap to a T56 that I was going to need a different driveshaft.
Old Feb 16, 2004 | 07:08 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
They are not all the same. Most LS1's came with a 3" aluminum shatf. You will find that it is hard to beat the value and performace of the LS1 aluminum shaft. However some 2.73 geared LS1's came with a steel shaft. All LT1's came with a steel shaft and some were balanced and others not. Get yourself an LS1 shaft and never look back.
Old Feb 16, 2004 | 10:35 PM
carfixxer's Avatar
Car: 87 GN & 87 T
Engine: 3.8 V6
Transmission: 200r4
Oh MY! I forget when I post on here I have to spell out every detail.
The reason I didnt mention "aluminum driveshaft" or steel drive shaft is that we were speaking of fit not material.
So, a late model aluminum drive shaft is fully interchageable, regardles of transmission, rear end, from 1982-2000.
Old Feb 16, 2004 | 11:11 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Yea you are right. Sorry for the confusion. I think we thought that you meant you could get any old driveshaft from various f-bods and have them be the same in every way like the rear stamped LCA's and panhard rod.
Old Feb 16, 2004 | 11:26 PM
pasky's Avatar
Nope, interchangable. Believe its when you keep the older 82-83 transmission and put a new driveshaft they won't fit, but pretty positive all other years will fit using a t-5, 700r4, 4l60e, and t-56.
Old Feb 17, 2004 | 01:54 AM
Car: 89 RS
4th gen driveshaft
Thanks for the advice, although I'm still a little confused.
Do I just tell them I want one for a 98 Camaro and it will be aluminum and will work?
Jamie
Old Feb 17, 2004 | 02:01 AM
pasky's Avatar
Just be specific, say you want a aluminum driveshaft from a 98+ fourth gen camaro or trans am, ask if its 3" in diameter. If its 2.75, thats a 1LE aluminum driveshaft.
Old Feb 17, 2004 | 02:30 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
who is "them?"
dont pay more than $150 for a driveshaft (used)
Old Feb 17, 2004 | 11:15 AM
Car: 89 RS
"Them" is the local used parts yard. They have their own junkyard, plus can order parts they don't have from all over the country from other used part yards.
I wasn't sure how much one would go for, but there is one on eBay right now going for $130+. It's from an LS1.
Jamie
Originally posted by Token
who is "them?"
Old Feb 17, 2004 | 11:29 AM
Car: 89 RS
I just called the local parts yard and asked for the shaft from a 98 and they wanted to know if it was with or without the 3 4 2 ratio. He said the standard and auto are the same, but I need to know the ratio? What the heck is he talking about?
Jamie
Old Feb 17, 2004 | 11:54 AM
Bandit5's Avatar
The rear gear ration. He asked if you had 3.42 gears in the rear... just say "yeah" I don't think it matters.
Old Feb 17, 2004 | 03:32 PM
pasky's Avatar
Just nod andc agree, it doesn't matter what the rear ratio was, its not like the ratio will space thne damn rear end anymore, just get the driveshaft.
Old Feb 17, 2004 | 04:14 PM
91FireChicken's Avatar
Car: 91 Firebird
Transmission: A4
to summarize and clarify... 98+ driveshaft for a v8, that did not have auto and 2.73 rear gears.. it'll be 3" diameter.. the smaller diameter (I think it was either 2.5" or 2.75") was a 1LE driveshaft that came in some thirdgens and a few fourthgens if I remember right.. but you'd probably rather have the 3" LS1 driveshaft, since it'll be stronger.. and yes, ANY 84 and up (not sure about 82-83) driveshaft is interchangeable.. make sure to get the u-joints with it if you can..
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
