Th-400 ?
Car: 4
Engine: 6
Transmission: 5
Practically everything with a motor bigger than a 350, from 65 to sometime in the 80s. Especially (but by no means exclusively) full-size cars, and trucks.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1964-1990 although they stopped putting them in cars in the early to mid 70's. Mostly found in pickup trucks and vans. Truck TH400's have a bolt on driveshaft yoke. You'll need a TH400 slip yoke from a car.
In 1991 GM changed the TH400 to the 4L80E. Many of the internal parts are the same except it has an overdrive and is computer controlled.
Car: 87 IROC L98
Installing a TH400 requires a new crossmember and a shorter driveshaft. It's not a direct swap to anything.
Car: 87 IROC L98
There are no cars with a driveshaft the correct length for a third gen with a TH400.
I think there's a conversion kit available for TH400 swaps. It will include everything need for the swap including a crossmember.
There might also be a FAQ on how to do the swap using and modifying a factory crossmember I think from a manual car.
You could also buy a Spohn torque arm and crossmember kit to do the swap.
Car: 87 IROC L98
There were many changes internally over the years. The best ones were 1970-71. All the internal parts are interchangable so you can mix and match the parts to get the best parts from all the years to build a very strong tranny.
Just make sure you get one with a chev bolt pattern. Most of the TH400's that were in cars have BOP bolt patterns.
Car: '82 Z28
1964, 1970, 400, bop, camaro, crossmember, driveshaft, length, lengths, parts, powerglide, shorttail, spohn, th400, thirdgen, transmission, vehicles, z28
