lowering springs?
Old Apr 13, 2001 | 01:21 PM
gemmefire's Avatar
lowering springs?
who makes v6 lowering springs i cant find n e all i find are v8 springs
Old Apr 13, 2001 | 03:09 PM
RenoLB8's Avatar
To my knowledge, noone. Get a hacksaw and start cutting.
-Reno
'88 Firebird LB8
"Cerberus"
-Supercharged Hybrid LB8/L32 Project-
"Got a green light, got a red light, no cop, no stop, man I don't care, every one of you could be the same, every one of you could play this game, got a green light, got a green light but you're going nowhere..."
http://www.angelfire.com/il/Firebird28/index.html
Old Apr 13, 2001 | 06:37 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
actually...someone found a link to some little obscure custom spring place on the net and they made some specifically for the v6 thirdgen...
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers (ready to install), Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil (Fireball in future) Accel 8.8 wires, MSD Ignition Module, 4th Gen Seats (not front yet)
" I'd rather run last in a full out race, than to NOT run at all ".
Old Apr 13, 2001 | 09:07 PM
gemmefire's Avatar
by chance you know the web site???
Old Apr 13, 2001 | 11:36 PM
nope...i bookmarked it but the link didnt work so either the url changed, place went outta business, or something
1989 Firebird
Old Apr 14, 2001 | 07:39 PM
84bird's Avatar
YES Suspention Techniques makes 1.3 inch all around lowering kit for 6 cyl.
Old Apr 14, 2001 | 10:22 PM
Camaro_hunter_d's Avatar
umm intrax and all the others that make springs make them for both the 8 and the 6. you just have to specify the 6er
Old Apr 16, 2001 | 10:11 AM
gemmefire's Avatar
if i was to cut the springs how much should i cut off?
Old Apr 16, 2001 | 03:17 PM
84bird's Avatar
Do not cut if first off the springs run from 99 to 239 dollars second your car has how many miles you'll just have worn out springs that are shorted second you can't use a tourch you will ruin the temper of the spring so it's a cutting wheel or hacksaw third how good is your eye you have to cut all 4 just right or handeling could be a disaster.just my .02
Bubbajones_ya
Jul 6, 2024 08:32 PM
Lanz06
Sep 14, 2015 07:16 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
