Moog front end kit??
Old Dec 23, 2003 | 10:04 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Does Moog have a complete front end kit for sale or do I have to piece one together?
Old Dec 23, 2003 | 10:59 AM
ede's Avatar
ede
never seen one but it might be out there. it's not hard to put one together, just walk up to the counter and tell them what you have and what pieces you want.
Old Dec 23, 2003 | 11:40 AM
Car: 91 RS
Engine: 350 TBI
What do I want?
I can think of the idler arm, control arm, ball joints and tie rods. . . ?
I'm going w/ poly bushings for the swaybar and its enlinks, so I won't need those.
What else am I missing?
Old Dec 23, 2003 | 11:52 AM
Dewey316's Avatar
Car: 1990 Camaro RS
you probably don't need new a-arms, but you will want new a-arm bushings. if you have the money, i would get global west del-a-lum bushings there.
for a TOTAL rebuild you will want.
Tie Rods 2 inner, 2 outer, a-arm bushings, idler arm, centerlink, pitman, ball joints, and i also suggest getting solid tie rod sleves, spohn, hotchis, edlebrock all sell them, but they are expensive. you can get them for cheap from coleman racing. you might also consider new strut mounts.
i think that pretty much covers it.
i will link you to a thread with part #'s from napa . . .
https://www.thirdgen.org/techbb2/sho...hreadid=197895
Old Dec 23, 2003 | 12:57 PM
Car: 91 RS
Engine: 350 TBI
So let me get this straight. . . according to that thread, Napa suspension parts are actually Moog parts with a Napa label on them?
Old Dec 23, 2003 | 01:20 PM
Dewey316's Avatar
Car: 1990 Camaro RS
the lower level is actualy moog. the MRC line. the NC line is better quality, i forget exactly what brand it is.
Old Dec 23, 2003 | 01:22 PM
Car: 91 RS
Engine: 350 TBI
HOLY CRAP! I had no idea that rebuilding the front suspension w/ Moog parts would be this expensive.This is what I got so far:
ball joints x 2
inner tie rods x 2
outer tie rods x 2
spohn tie rod sleeves x 2
idler arm
centerlink
EQUALS $493!
I haven't even gotten to the Energy Suspension control arm bushing kits, sway bar bushings, end links.
I think it might be time to go another route. I'll let yall know what I decide to do.
Old Dec 23, 2003 | 01:25 PM
Dewey316's Avatar
Car: 1990 Camaro RS
that cant' be right, i didn't spend nearly that much.
what part #'s are you using?
also, the spohn tie rod sleves are $$$, go to coleman racing, they are dirt cheap there.
Old Dec 23, 2003 | 01:48 PM
Car: 91 RS
Engine: 350 TBI
I used the ones that guy got from the linked thread you supplied.
I thought it was a bit much as well, but when you go to Napa's page it doesn't state if the price is for a pair (which I would imagine it would be) or for a single one. I calculated it as for a single one. Example:
tie rod inner / NCP 2692612 / $70 x 2 = $140
Now if in fact they actually are selling them as a pair at the displayed price then my new total for above said parts (minus the Spohn sleeves and adding the Coleman ones) would be $304.
Now that's much better.
Old Dec 23, 2003 | 01:51 PM
Dewey316's Avatar
Car: 1990 Camaro RS
the moog part numbers are the next line down, the MRC part #'s
Old Dec 23, 2003 | 01:54 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
spohn sells the moog front end rebulid kit
$342.60
Old Dec 23, 2003 | 02:00 PM
Car: 91 RS
Engine: 350 TBI
$342.60
So essentially, I'm saving myself about $40 plus what ever shipping is, unless of course you consider the Spohn tie rod sleeves worth the extra money.
Old Dec 23, 2003 | 02:04 PM
Car: 91 RS
Engine: 350 TBI
Also, adding the TDS front and rear sway bar bushing kits for $82 and $10 for the endlink kit, I'm now up to $396. I haven't been able to find the price of the control arm bushing kit from Energy Suspension, but I might just let that one slide.
Old Dec 23, 2003 | 02:15 PM
Dewey316's Avatar
Car: 1990 Camaro RS
ok here is a break down of the moog parts from napa
MRC-10277 $ 13.49 X2 (Ball Joints) 26.98
MRC-ES2226R $ 16.99 X2 (Tie Rod) 33.98
MRC-ES2226L $ 16.99 X2 (Tie Rod) 33.98
MRC-18832 $ 37.99 (Idler Arm)
MRC-DS1049 $ 44.99 (Centerlink)
That comes to 177.92
Add the colemand sleeves.
RP-129-4 4" Steel Tie Rod Sleeve $8.65 X2 17.30
+ Jam nuts
941-L 5/8" Left .85 X2 1.70
941-R 5/8" Right .60 X2 1.20
All of that comes to a total of $198.12 the only shipping cost will be on the tie rod sleeves, the rest can be had at the local napa store. and you just did a moog front end rebuild for under 200 bones.
Old Dec 23, 2003 | 02:16 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Energy suspension part #
ENS-3-3157G
it is $31.95 from Summit.
Old Dec 23, 2003 | 06:04 PM
MilehighBird's Avatar
Car: 1987 Firebird Formula
Engine: 305 LG4
summit also carries the moog suspension parts you were looking for.Thats where I got my stuff.They were way less expensive than napa.
Old Dec 23, 2003 | 11:58 PM
Car: 91 RS
Engine: 350 TBI
+ Jam nuts
Thanks man. You da man.:hail:
Old Feb 27, 2005 | 02:14 AM
JohnS's Avatar
Car: 2004 Nissan 350Z
Engine: 3.5 V6
Transmission: 5 speed auto
just wanna say thanks to Dewey316. i used your parts# list you posted for my front end rebuild and took it to Napa, i just wanted to see if the prices were the same or close to it, but before i said i just wanted to check prices, the guy said we'll match these prices since you got them off a website. i got the inner/outer tie rods, ball joints, idler arm & centerlink for $178 after tax
Old Sep 30, 2005 | 09:55 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
+ Jam nuts
ttt. i wish i read this monday when i ordered all thoes moog parts.. lol.
Old Sep 30, 2005 | 10:04 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Autozones Duralast parts are moog as well relabeled. We used them on my GF's RS. Fit and works perfect.
Old Sep 30, 2005 | 03:13 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
McQuary-Norris also... I think thats how you spell it.
Of course it isnt necessarily Moog, but Federal Mogul.. again spelling
Old Oct 1, 2005 | 05:45 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
For those that care to know, while I believe the MRC parts are indeed Moog parts, NAPA's top of the line NPC brand is not manufactured by Federal Mogul (Moog). They are made by the Dana corporation. (They also make the Perfect Circle brand).
Old Oct 2, 2005 | 06:22 AM
TapouT's Avatar
Car: 92 rs
Engine: lo3 kinda
Just curious, but is it worth the extra cash to go to the npc line? For a daily driver is the mrc line sufficient? I'm getting ready to drop some cash on a front rebuild and wondering if I need to pour cash for quality or if I can get away with economy for a dd.
Old Oct 2, 2005 | 03:25 PM
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
I've heard many times that the NPC parts just look beefier than the Moog parts. Whether than means they worth the extra money or not is not an easy question to answer. The life of these parts, even cheap ones, are pretty long if properly maintained. I have not been to a NAPA to verify it for myself.
Old Oct 3, 2005 | 03:21 PM
Dewey316's Avatar
Car: 1990 Camaro RS
I like the NPC stuff, Especialy the Ball Joints, and Idler arm. The tie rods are beafier, I don't know that they are needed in most applications, I went with the MRC tie rods, and they have handled the abuse I can throw at them.
Old Oct 5, 2005 | 05:03 AM
TapouT's Avatar
Car: 92 rs
Engine: lo3 kinda
Maybe a stupid question, but if they look beefier, is the thread diameter the same? I mean I plan on getting the aftermarket tie rod sleeves like spohns or coleman, would those fit the npc line or would I have to do some shopping? Excuse my ingorance, but that's why I'm here.
Old Oct 5, 2005 | 09:44 AM
Trans Am#5's Avatar
Car: 1987 Trans Am
Engine: Lt1
Try these guys:
www.rockauto.com
Old Oct 5, 2005 | 03:55 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Same thread size, as they are meant to be stock replacements.
Old Oct 5, 2005 | 10:48 PM
KBeez's Avatar
Car: 88 Camaro S/C
Transmission: 700-R4
Hey I'm tagging this topic for later, this is a great topic btw, very resourceful.
Old Dec 28, 2005 | 01:30 AM
TapouT's Avatar
Car: 92 rs
Engine: lo3 kinda
Bringing up a little outdated thread, but I just went to napa today and ordered tie rods, centerlink, ball joints and compared the mrc line and the ncp line. I was impressed at how much sturdier the ncp line was compared with the mrc line so I decided to shell out the extra cash. Just my .02 about this. I would rather not rebuild the front end any time soon if the extra cash keeps me from it, I plan on keeping my 3rd gen for quite a while.
Old Dec 29, 2005 | 02:09 AM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Made in Taiwan
I've pretty much bought the entire front end parts from NAPA. Mostly the MRC line. I noticed today as I was going to get the ball joints installed one was labled Made in Taiwan. Went back to NAPA and had it exchanged for the Made in USA. Lots have touted the Moog line because it's Made in usa. I guess not all are.
Old Dec 29, 2005 | 09:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
For what its worth, here was my shopping list: https://www.thirdgen.org/techbb2/sho...hreadid=184552
I also had shocks, struts, spring isolators, and even new bolts- find info on the GM part #s for bolts here: https://www.thirdgen.org/techbb2/sho...hreadid=184591
Yes its expensive once it starts adding up... and it can add up quick!
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
bellez77
Sep 5, 2015 08:39 PM
